Help? Tire presure sensor
Old Feb 20, 2005 | 06:51 PM
capt1mike's Avatar
capt1mike
Default Help? Tire presure sensor
One of my tires reads XXXX Do it need a new one or can it be reset? If reset, how do i do that? Thanks Capt1Mike
Old Feb 20, 2005 | 10:28 PM
coast7's Avatar
coast7
Capt1Mike,
Here are the steps to program the TPS from the GM Service Manual. Depending on your car's age/mileage, the battery in your TPS may be failing. But try to reprogram it first. No damage to your car will result from a bad sensor, other than not knowing the tire air pressure from the inside of the car. Several forum vendors offer replacement sensors at less cost than a dealership. If you must order a replacement, note there are two versions, one for early models (97-00) and another for the later models (01-04). The programming tool mentioned is just a magnet. Any good one from Home Depot will work. Just hold it near the valve stem until the horn sounds, then move on to the next wheel. I believe you should program all four wheels, not just the one giving the bad reading.
Tire Pressure Monitoring Sensor Programming
The Tire Pressure Monitor (TPM) system interfaces with the Instrument Panel Cluster (IPC) through the serial data line. Once the program mode is accessed through the IPC, each sensor's unique identification code can be programmed into the receiver's memory. Each sensor must transmit the unique code in the proper sequence. A magnet must be held close to the sensor in order to force the sensor to transmit the identification code. The IPC will display a message as each sensor is programmed, and when to proceed to the next sensor for programming. The receiver also sends a message to the BCM to sound the horn one time, indicating that the sensor properly transmitted an identification code. If the programming sequence is cancelled before any sensor is programmed, or if the vehicle's battery is disconnected, the receiver will remember all current identification codes. As soon as the receiver learns the first sensor identification code, all previously stored codes are erased from the receiver's memory.
Programming TPM Sensors
Tool Required
J 41760 Tire Pressure Monitor (TPM) System Programmer.
Important
Make sure the vehicle has been stationary for at least 2 minutes before attempting to program the TPM sensors.
Turn the ignition to ON.
Press the RESET button in order to clear any IPC display warning messages.
Press and release the OPTIONS button on the DIC to scroll through the display options until the IPC display is blank.
Press and hold the DIC RESET button for 3 seconds.
Press the OPTIONS button again until the TIRE TRAINING message appears.
Press the RESET button until the IPC LEARN L FRONT TIRE message appears in order to begin the programming sequence.
Install the J 41760 J 41760 over the left front valve stem.
The horn will sound, indicating the left front TPM sensor is programmed.
Important
If the horn does not sound after 15 seconds, remove then reinstall the TPM sensor programming tool. This procedure may have to be attempted up to three times in some instances.
When the horn sounds, proceed to program the next TPM sensor in the following order as directed by the IPC messages:
LEARN R FRONT TIRE
LEARN R REAR TIRE
LEARN L REAR TIRE
Programming Cancellation
The programming mode will be cancelled if any of the following conditions are met:
The program mode is exited through the DIC.
The ignition is turned to OFF.
All four sensors have been programmed.
The TPM system has been in the program mode for longer than 2 minutes and no sensors have been learned.
If the program mode is cancelled with less than four codes stored, the receiver will only accept the codes programmed up to that point.
Old Feb 21, 2005 | 11:35 PM
texasredc8's Avatar
texasredc8
Your sensor battery may be depleted. Hopefully not.
I had this happen on an older C5. Put some air in the tire, bled some out a few times, and it started working again.
If you want to try the re-programming method, you'll need a strong magnet. I purchased a rare-earth hobby magnet that is the size of a 50cent piece. $5. Found it at a local Electronic Supply shop.
To Help? Tire presure sensor
