SS Brakes Lines - Worth it?
Old Feb 20, 2005 | 08:58 PM
1FUNVTT's Avatar
1FUNVTT
Default SS Brakes Lines - Worth it?
Thinking about modifying my brakes with vented slotted rotors and ss lines. The car will mostly see street actions... maybe a driving course now & then. A stock engine with some intake & exhaust mods. My question: Will I notice the different? and Do you think the ss lines are worth the $$?
Old Feb 20, 2005 | 09:18 PM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
Old Feb 21, 2005 | 05:17 AM
Sportsdude's Avatar
Sportsdude
I recently read (can't find the post) that it's recommended to keep the original setup if running stock application.
Old Feb 21, 2005 | 05:47 AM
Wolfmanjohn's Avatar
Wolfmanjohn
Greetings, Greg,
There seems to be an issue with SS lines allowing static electricity buildup, which causes erroneous wheel sensor readings/feedback to the PCM, and resultant codes.
Functionally, though, they will firm up pad application and pedal feel......a little bit.
Old Feb 21, 2005 | 06:29 AM
Mighty-Mouse's Avatar
Mighty-Mouse
Lengthy post on the subject covering pros and cons:
http://forums.corvetteforum.com/show....php?t=1009075
Old Feb 21, 2005 | 06:53 AM
jim2527's Avatar
jim2527
Originally Posted by BW1
Trying to run up your post count? The number reason why I hate the corvetteforum.....dupe dupe dupe it really isnt cool.
Old Feb 21, 2005 | 07:50 AM
John Shiels's Avatar
John Shiels
From: Buy USA products! Check the label! Employ Americans
no is the answer
Old Feb 21, 2005 | 09:32 AM
Richin Chicago's Avatar
Richin Chicago
Not worth the effort unless you going to do some serious roadcourse driving.
Old Feb 21, 2005 | 09:43 AM
sprinter's Avatar
sprinter
Had a coupon with Summit so they cost me $80 (shipping included). Had to bleed my brakes anyway so I thought it was a good time to upgrade cheaply.
Old Feb 21, 2005 | 09:51 AM
Mr. Lucky's Avatar
Mr. Lucky
St. Jude Donor '06
As a matter of fact, no. But thank you you ever so much for asking.
Who's making you stay? I agree that people who make "hit & run posts" with nothing more than "Dupe" or "I agree" add no value and serves only to increase post count (not to mention that it is against forum rules). However... if you had bothered to look, you would have seen that the dupe image I posted was also a link to the earlier post from the same person, where the same question was asked.
The OP probably thought he was doing the right thing to ensure his question got seen by the maximum number of people who might be able to help. What do you think the Dupe smilie is for anyway? Answer: It serves as a light-hearted way of reminding members that multi-posting is not acceptable.
Old Feb 21, 2005 | 09:53 AM
devo's Avatar
devo
St. Jude Donor '03 & '05
$80.00!
that is cheap, like $20.00 a line!
I would do it for that price and if I didnt like them or if they threw codes, swap em out.
Old Feb 21, 2005 | 12:07 PM
1FUNVTT's Avatar
1FUNVTT
Default Thanks for your inputs
Thanks for all your input. Sounds like 65% responses are favorable (from both of my posted threads) with possible side effects. That’s why I like the CF. It is a great resource, so you can make the most informed decision about your Vette.
To Wolfmanjohn - PM sent.
To BW1 - Sorry for not knowing the CF rule about “dupe” posting. Your right; trying to get as much opinions & info. I am better informed.
To Jim2527 - No comment.
Old Feb 21, 2005 | 12:32 PM
Cobra4B's Avatar
Cobra4B
CI 3-5-6-7-8 Veteran
Unless you are running HPDE's then don't bother with them. I have them and they're great, but you won't appreciate the benefits unless running very hard.
Old Feb 21, 2005 | 02:37 PM
MassaRusty's Avatar
MassaRusty
I never realized that you could actually click on the "dupe" icon. I thought it was just like all the other things you can add to your post. I also thought that people were just being asses when they did that knowing the search didn't work so well. I am now enlightened.
Old Feb 21, 2005 | 03:38 PM
MHVette's Avatar
MHVette
This is also news to me!
To SS Brakes Lines - Worth it?
