Best Alignment specs for 2000 Corvette
Old Feb 21, 2005 | 01:25 PM
YO-EL's Avatar
YO-EL
Default Best Alignment specs for 2000 Corvette
95% track driven
2002 Z06 specs?
Old Feb 21, 2005 | 01:52 PM
BlueDragon's Avatar
BlueDragon
Depends!
What are you running? What tires? did you upgrade the suspension? If it is stock is it the Z51 etc.
You said 95% track? Drag strip? Autocross? Open track?
Alignment is almost a personal thing.
Largely stock and Non-runcraps go Z06 alignment specs, If you have run craps fo with a agressive stock 2000 alignment (slightly more neg camber) just remember the more camber the more the inside tire wear.
Not enough info to answer your question.
Old Feb 21, 2005 | 03:10 PM
dajael
Guest
Posts: n/a
http://forums.corvetteforum.com/showthread.php?t=984927
About half way down the page...
HTH,
Old Feb 21, 2005 | 03:21 PM
YO-EL's Avatar
YO-EL
Sorry guys..
Car is 95% drag raced track car, the other 5% is driving to & from the track..
Lowered with BASE suspension, Bilstein Sport shocks...
19/20" Michlein Pilot Sport 2 tires..
Car runs straight & true, no pull when braking, but I'm noticing some "slight" wear on the OUTSIDE tread of each FRONT tire...
What do you guys suggest now?
Old Feb 21, 2005 | 05:35 PM
BlueDragon's Avatar
BlueDragon
Ok, you are a drag racer. Makes a big diff! You have wear on the outside edge? Not good! Wear should be to the inside edge. Could be too much toe in and not enough neg camber. Being you are a drag racer, I would go with the stock alignment and dial the rear camber to zero with zero toe, for the front I would go with the stock 2000 toe, 6, - 6.5 caster and maybe 3/4 degree of negative camber. I would keep the toe to the low end and when I go to the drag strip I would over inflate the fronts to get them up on the inside edge to reduce rolling friction. (effectively like a drag skinny)
The caster is what will keep you straight. I would not go over a degree of negative camber on street tires. Run Craps will only tolerate a half of a degree before they really start to wear on the in side. No run crap will take a little more.
Old Feb 21, 2005 | 08:53 PM
YO-EL's Avatar
YO-EL
Wow.. sounds like you know what you're talking about!@
What is your experience before I try your suggestions?
Old Feb 22, 2005 | 12:07 AM
C5 KIDD's Avatar
C5 KIDD
Cruise-In VI Veteran
sounds like good advice!! just wish i can find a shop to get me up on the lift!!!
does the Z06 specs really make that much of a difference? will you notice the car handling better? im lowered, Z06 sways, and bilsteins sports.
i would like to go Z06, but worried about wearing out my new kumho MX's real quick. how bad of an effect with Z06 spec??
Old Feb 22, 2005 | 10:53 AM
BlueDragon's Avatar
BlueDragon
I stayed at a Holiday Inn once
Silver6spd,
If you run factory Z06 specs and are running non-run craps, your wear will be no worse than a factory stock Z06. The key here is the tire sidewall. The standard C5 with run-craps will not tolerate much more than a half a degree of camber. Anything over that will start to increase tire wear. The EMT sidewalls are so stiff they do not allow the tire to sit flat with more camber hence wearing the tire faster.
You should be good with factory Z06 specs. Thing is make sure the alignment shop knows what they are doing and have a good Lazer alignment machine and that it is calibrated. If they can't get you on the lift, I would take that as a caution as to maybe they don't do that many C5s.
Old Feb 22, 2005 | 01:14 PM
lost's Avatar
lost
I'm a dummy and stayed at Motel6 and used the money I saved for mods !
Old Feb 22, 2005 | 02:38 PM
YO-EL's Avatar
YO-EL
I'm gonna try your tips..
REAR:
0 toe
0 camber
Front
Toe = 6
Caster = -6
3/4 degree negative camber..
Thanks again.
But, the specs look like this:
Can YOU fill in what they should be? thanks!
Front Alignment Specs Service Allowable Service Preferred
Front Individual Toe
Front Sum Toe
Front Individual Camber
Front Cross Camber
Front Individual Caster
Front Cross Caster
Steering Wheel Angle
Rear Alignment Specs Service Allowable Service Preferred
Rear Individual Toe
Rear Sum Toe
Rear Thrust Angle
Rear Individual Camber
Rear Cross Camber
Old Feb 22, 2005 | 03:02 PM
BlueDragon's Avatar
BlueDragon
No the front toe is wrong, should be.
Front non Z06
Camber -.5 to -.7 degrees (Non runflats) stock range is -.5 to a -.1
Caster 6.0 to 6.9 degrees (what ever the stock setting is fine as long as it is more than 6 degrees and not over 7 degrees)
toe in -.07 degree stock range is -.05 to -.15
Rear toe 0 or as close as they can get
Rear Camber 0 or as close as they can get
REAR:
0 toe
0 camber
Front
Toe = 6
Caster = -6
Thanks again.
Old Feb 22, 2005 | 03:20 PM
YO-EL's Avatar
YO-EL
Lets try this again..
OK.. so for my car a drag raced car with 19" non run flats up front & 17" drag radials in the rear: You say shoot for this:
Front Individual Toe -.07 to -.09 In your case lower is better, stick close to -.07.
Front Sum Toe -.14 to -16 (depending on above)
Front Individual Camber -.75 (only if you do not have runflats)
Front Cross Camber -.1
Front Individual Caster 6.5
Front Cross Caster -.4
Steering Wheel Angle, Straight
Rear Individual Toe 0.0 (stock range is -0.5 to -0.1
Rear Sum Toe function of above not to exceed -0.2
Rear Thrust Angle 0.00
Rear Individual Camber 0.00 (stock range is -.5 to -.1
Rear Cross Camber hum, never measured it, Thrust angle and toe is all you need.
Old Feb 22, 2005 | 04:08 PM
BlueDragon's Avatar
BlueDragon
Old Feb 22, 2005 | 04:10 PM
YO-EL's Avatar
YO-EL
THANKS GERALD!
Gonna try it!
To Best Alignment specs for 2000 Corvette
