Coolant Change??
Old Feb 22, 2005 | 09:24 PM
Fat Finger's Avatar
Fat Finger
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Default Coolant Change??
Plan to replace the coolant in my '99. Dex-Cool is recommended. Has anyone heard/read of any issues with Dex-Cool? Any suggestions on another brand?
Thanks in advance!
Old Feb 22, 2005 | 09:31 PM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Its fine...buy the Pre-mix version it makes it easier
Old Feb 22, 2005 | 10:39 PM
2toys's Avatar
2toys
You really should consider having the system flushed rather than drain and refill. The dexcool is rated for 5 years/100,000 miles, you are at the 5 year limit. The experience I've seen with extended life coolants is they tend to thicken [change viscosity] when left in too long, four years is a good change point. You might consider the flush before refill.
A word of caution I couldn't help but slop some coolant on my belts when I hooked up the unit, it won't come off and they chirp like hell. I figured the car is a 98 and although it only had 24,000 miles the belts could stand to be replaced. I keep the old ones in the trunk, never know.
To Coolant Change??
