HID conversion kit
Old Feb 23, 2005 | 12:10 AM
corvettefrance's Avatar
corvettefrance
Default HID conversion kit
I found that you can buy a HID conversion kit for $300 on ebay.
As anyone of you already bought one?
Can you really see the difference
Old Feb 24, 2005 | 01:23 AM
exstanger's Avatar
exstanger
Do it. You can definitely tell the difference and actually I have 6000K which is a spark blue color and I have not been flashed by oncoming traffic yet.
Old Feb 24, 2005 | 02:02 AM
BlingLights's Avatar
BlingLights
Hi,
Please compare the kit you found to the kits we carry at www.BlingLights.com
Thank you
-Jason
jason@blinglights.com
Old Feb 24, 2005 | 12:06 PM
vmspionage's Avatar
vmspionage
I picked up a 6k HID kit from proxenon on ebay for 280 shipped, supposedly it's a Phillips bulb and Hella ballast. Anyways I was running the kit installed in the stock popups before I switched to SW C5Rs for a few weeks and it looked great! Go for it
Old Feb 24, 2005 | 12:14 PM
rudolph schenker's Avatar
rudolph schenker
HIDs are significantly better. You will be happy with the upgrade!!
Old Feb 24, 2005 | 04:09 PM
Gimmesum HP's Avatar
Gimmesum HP
One of the best bang for the buck mods I've done so far. Go for it.
Old Feb 24, 2005 | 04:12 PM
SS930's Avatar
SS930
Popcorn anyone???
Old Feb 24, 2005 | 04:42 PM
Skyguy^^'s Avatar
Skyguy^^
IMHO, unless the kit contains projector lenses, it's not true HID. you will not get the required cutoff and could potentially blind oncoming motorists. For more information read this:
http://faqlight.carpassion.info/retro-vs-oem.htm
Old Feb 26, 2005 | 05:11 PM
BlingLights
Here is a photo from member culookin comparing halogen on one side to HID on the other on a C5 with stock lowbeams and a kit through www.BlingLights.com
Old Feb 26, 2005 | 10:51 PM
Sportsdude's Avatar
Sportsdude
How long are the cables? Are the 50W version brighter?
Old Feb 27, 2005 | 01:49 AM
BlingLights
The standard HIDs are more then bright enough for most people. The 50 watt Very High Output HIDs are much brighter then standard HIDs. The Sunshine Brand we carry has the longest cables of any brand. You can mount them on a chopper with the ballast installed in the body with slack to spare. The Far Vision brand we carry also provides lots of slack.
To get a factory HID look as seen on the new Mercedes primarily for increased visability go with a 4300K. To achieve the look of the Lexus or Infiniti headlights go with a 6000K, which provide a hint of blue. 8000K will provide a white beam with an attractive blue hue. 12000K is mostly for show and will provide a purple output.
All they styles are dramatically brighter then any non-HID setup. When comparing HIDs to one another the higher the number the more showy and the lower the number the more visability. The Very High Output HIDs are good because you can go for show and still have more then enough output to see down a long streatch of highway.
For further detail email me anytime at jason@blinglights.com Thank you
Old Feb 27, 2005 | 03:05 PM
BuckyThreadkiller's Avatar
BuckyThreadkiller
Successful Plumber
From: Top of the hill, 3rd mailbox on the right. Texas
CF NCM Ambassador
CI 6-7-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10
NCM Member '09
Jason -
What is involved in the conversion and installation? I'm terribly disappointed in the stock C5 headlights and want to upgrade the performance of the lights. I really am not interested in the exterior look of the lamps - I don't care about blue tints or Angel eyes or the "bling factor" I want lights that illuminate the road at speed and will last.
But obviously I don't know squat about headlights. Can you help me out.
Old Feb 27, 2005 | 03:13 PM
BAD Z06's Avatar
BAD Z06
I love my HIDs!! you will see a hugh difference
Old Feb 27, 2005 | 03:29 PM
BlingLights
Originally Posted by BuckyThreadkiller
Jason -
To install the HID kit is quite simple but for anyone not comfortable doing it I recommend getting help.
1) First remove your stock halogen bulbs
2) Plug the factory harness from the halogen bulb into the plug coming out from the HID Ballasts
3) Plug the HID bulbs into the headlamp the same as a regular halogen bulb
4) plug the ballast cable to the HID bulb just like the factory harness would plug into the halogen bulb
5) secure the ballasts in place with either some double-sided tape and zip tie any loose cables away from hot or moving parts
That is it! For a few corvettes of certian model years the use of a relay from your local hardware store for less then $5 may be needed. Otherwise the lowbeams can only be turned on by going from the high beams first but only heard this from 2 members.
If your not at all concerned about acheiving the blue exotic appearance and just want maximum visability go for a 4300K or a 6000K for a hint of blue. 8000K is a little more showy but still much brighter then any non-HID setup. Thank you
-Jason
Jason@BlingLights.com
Old Feb 27, 2005 | 05:10 PM
BuckyThreadkiller
Successful Plumber
CF NCM Ambassador
CI 6-7-9-10 Veteran
NCM Member '09
-Jason
Sounds like it's pretty much a plug-n-play mod. Are there heat or electrical load concerns?
I've got a 2001 Coupe - would that require the relay?
Old Feb 28, 2005 | 12:54 PM
BlingLights
Both the standard HID and VHO HID use less current then the factory halogen bulbs. The HID kits are just more efficient. There is no filament in a real xenon bulb, just a mixture of rare earth elements. A set of high wattage cheap tinted bulbs emits more damageing heat then true HID bulbs. A set of tinted halogen bulbs over time can melt the seal around a headlamp housing causing the headlight to collect moisture. The kit when installed properly is safe for the car and frees up current for other accessories. I only mentioned adding a relay because 2 members told me they did so but the majority of C5 owners did without the relay. If your comfortable installing on your own it is not difficult but if you have any doubts I recommend haveing it done at a local tuner shop.
To HID conversion kit
