Muffler gaskets?
Old Feb 23, 2005 | 07:27 AM
Derf's Avatar
Derf
Default Muffler gaskets?
Changing out the exhaust, stock to TI. Should the gaskets where the cat backs join the rest be replaced? Are there different gasket sets, I have heard of copper used. Suggestions please
Old Feb 23, 2005 | 11:03 AM
GUSTO14's Avatar
GUSTO14
Yes you're gonna want to change out these gaskets. They're about $7 each from most of the vendors or your local Chevy Dealer.
http://www.gmpartsdirect.com/ works well… last a long time![I]
You might consider new bolts as well, they're 10mm x 1.25 and available at any good hardware store. You'll need 4 of them. I used stainless steel with some anti-seize to preclude problems in the future.
GUSTO
Old Feb 23, 2005 | 11:11 AM
mike348's Avatar
mike348
I used my old gaskets without any leaks. Car had 9000 miles. You can change them real easy if they leak. I used the same bolts.
Old Feb 23, 2005 | 11:33 AM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
I used my old ones without any leaks. Sprayed some copper on them first though.
Old Feb 23, 2005 | 08:22 PM
leaftye's Avatar
leaftye
I broke my gaskets.... I suggest having replacement gaskets on hand.
To Muffler gaskets?
