Trying to pull the rear suspension apart for poly bushings and new wheel studs. Got the spindle nut off, split the top ball joint and loosened the bottom one, but can't get the damn spindle out of the bearing assembly. Can anyone confirm that this tool will work before I buy it?
it should come right out providing you break loose the lower ball joint so you can move the knuckle enough for clearance. just did mine last week for a bearing replacement and it was smooth.
i rremoved the nut from the lower ball joint then jacked up the spindle and the weight of the car pulled the ball joint apart.
That was my first thought, but I read that you can screw up the diff and/or halfshaft if you do that.
The axle shaft floats in the inner joint so damadging the diff is not a concern.The axle shaft has a dimple on the end which will prevent the punch from slipping off the end off the shaft causing thread damage.You may want to use a brass punch.If the axle is seized in the hub which is very common,the tool above will more than likely worp your hub flange
Not sure if I understand... Are you trying to fully break the lower ball joint loose? If you are, check out the tool in my pictures. It's the factory ball joint separator tool.
Thanks for the help guys, couple of good whacks with a hammer and block of wood and out it came!
Leaftye - it was the axle that I couldn't separate from the bearing assembly. Splines had a bit of rust on them which probably contributed to it being so tight.
