FAST Intake Owners Opinions please
Old Feb 23, 2005 | 10:08 PM
YLWFVR75's Avatar
YLWFVR75
SE Michigan Coordinator
CI 3, 4, 5, 6, 10 Veteran
St. Jude Donor '09-'11,-'13-'14-'15
Default FAST Intake Owners Opinions please
What has your experience been like with the FAST LSX Intake Manifold? What kind of HP/TQ gains did see?
Please indicate if your a LS1 or LS6
Old Feb 23, 2005 | 10:19 PM
SweetSavannah's Avatar
SweetSavannah
I've had two experiences, both from LPE.
1. On a 427 N.A. motor, I picked up approximately 25 RWHP vs the regular intake they were using.
2. On a 427 TT motor, I picked up approx 40 RWHP vs the standard intake LPE uses.
They've told me the bigger the motor, the more gains you can typically expect to see. On the other end of the spectrum, a FAST 90 doesn't seem to produce material HP gains on a stock motor.
Old Feb 23, 2005 | 10:24 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
I can't say anything about actual HP gains as I didn't dyno beforehand. I would guess 15 - 20 hp max.
I used Nick Williams' 90 mm TB, with the 90mm LSX and the change in driveability due to increased part throttle response was huge. Definitely worth it!
See sig. for mods.
Old Feb 23, 2005 | 10:28 PM
90 droptop's Avatar
90 droptop
408 ls6 intake ported stock t-body to fast 90 with NW t-body 18 rwhp
Old Feb 23, 2005 | 10:33 PM
The DBK's Avatar
The DBK
zack,
What else are you doing to the car? Is it still bolt-ons or are you doing additional work?
I've got a LSx/90mm combo on my car, but I never dynoed it before I added them. I'm guessing 15-20rwhp.
I don't know if you've talked to Phil about it, but I was under the impression he thought the LS2 intake would provide a more liveable setup with only moderate work to retrofit it to an LS1...
Old Feb 24, 2005 | 10:40 AM
YLWFVR75's Avatar
YLWFVR75
Thanks for all the replies.
If I were to do this, I would probably stay with the stock 78mm TB.
I didnt see that FAST makes a electronic TB.
Will the stock rail covers still fit on this manifold?
Old Feb 24, 2005 | 11:12 AM
C5X2C's Avatar
C5X2C
The stock rail covers will fit perfectly................. after your custom grind is complete.
I just finished cutting mine with a dremil tool. I put the covers in place as close as I could and used chalk to scribe where the grinding was needed. It took me approx 20 close fits and scribing before they would secure completely in place. Try not to slip and grind the top of the covers, that was the only pitfall.
Old Feb 24, 2005 | 12:09 PM
gojo's Avatar
gojo
I picked up 20 hp with the 90mm setup and then 25 hp upgrading my heads from 2.0 to 2.5 comp. level. I was not happy with the gains before these changes and was really surprised at the sudden bump. It seems what everyone says about the whole package making a difference showed up with my car.
Old Feb 24, 2005 | 02:07 PM
YLWFVR75's Avatar
YLWFVR75
is anyone running the stock 78mm TB with their FAST Intake?
Is the 90mm TB some of you are posting, from the LS2?
Old Feb 24, 2005 | 02:48 PM
THRLSKR's Avatar
THRLSKR
If you are going to get a FAST - go with the 90TB from Nick Williams (LG Motorsports sells them)....You will pick up 10RWHP for a cam only car plus 5-10TQ everywhere....20+ for heads and cam.
The 90 drives fine with the NW TB and good tuning.
78 you are waisting time and money.
Bill
Old Feb 24, 2005 | 03:41 PM
ArKay99's Avatar
ArKay99
BLACKTOP2000 had a stock LS6 manifold and unported 75mm tb and made 415rwhp from his current h/c setup. He recently put an LSX 90mm manifold and an LS2 tb on. We will be going to the dyno in a few weeks. We just have to zero in on the part throttle tuning. Drivability with this combo is amazing. Drives and idles just like stock... well maybe just a tiny bit of lope. SOTP says 15-20rwhp. I wish it would stop snowing so we can do some more logging. Will post the results when we have them.
Old Feb 24, 2005 | 03:58 PM
Tony Mamo @ AFR's Avatar
0Tony Mamo @ AFR
Former Vendor
The FAST 90 set-up will make the most power, the most torque, and carry the big numbers past peak HP better than any other intake/TB set-up on the market currently....It's no surprise that set-up is whats currently installed on my car. Hopefully even better stuff finds its way down the new product pipeline, but for now, the FAST is the least restrictive and puts down the strongest numbers...especially from 4500 to redline.
Tony M.
To FAST Intake Owners Opinions please
