My first time using ET streets
Old Feb 24, 2005 | 04:35 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Default My first time using ET streets
I'm going to go to the track tomorrow, weather permitting, and will be using ET Street for the first time. How big of a burn do you need on these? Should I dip into the water box? I'm also driving them to the track if no rain is present. 25 psi on the road and 12 psi at the track sound good? Thanks!
Old Feb 24, 2005 | 05:10 PM
kumar75150's Avatar
kumar75150
start around 15-16psi at the track and work your way down
go through the water and heat them up pretty well
Old Feb 24, 2005 | 05:12 PM
Cajundude's Avatar
Cajundude
Will do. Thanks!
Old Feb 24, 2005 | 05:27 PM
Face's Avatar
Face
What's your setup? A4/MN6, mods, etc..?
Old Feb 24, 2005 | 05:31 PM
Cajundude's Avatar
Cajundude
MN6. Just started building but started from ground up. Stock time was 12.93. Just finished building rear end with all of the DTE stuff. Going to track tomorrow to get new times. No other mods besides that. VaraRam goes in next week. Go to the track next Friday get those times. Exhaust after that, go to track, heads/cam after that, I think you get the picture by now
Old Feb 24, 2005 | 05:32 PM
Cajundude's Avatar
Cajundude
I'm going to post a time for every mod, one at a time, except maybe heads/cam, I'll certainly do those together.
Old Feb 24, 2005 | 05:34 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
Use the right lane @ HRP. I have gotten my best times there. Hope the weather turns better for you by tomorrow.
Old Feb 24, 2005 | 06:17 PM
90 droptop's Avatar
90 droptop
I used to air up 28 psi for the highway drive to the track. Air down to 13psi, dip them in the water about 1/4 turn and I would pull out of the water and then start the burnout. Don't soak the tires, when you start the burnout, it kicks water in the wheelwells and it will drip off on the tires when you stage. I would do a 4-8 second burnout. You want to release the linelock when you get thick deep smoke off the tires. No dry hop. Just stage and go.
Check your air pressure between rounds, it will go up after a pass because of heat. I also found 11-12 psi gave me the best traction. That may change through out the day.
Old Feb 24, 2005 | 06:39 PM
Dr.Ron's Avatar
Dr.Ron
From: 2007 Nat'l Corvette Challenge 11.50 index Champ. New Jersey
If they're new you'll need a good,long first burnout. After that, I think only a few seconds is needed..Good luck & post your results.
Ron
Old Feb 24, 2005 | 07:35 PM
RoadRebel's Avatar
RoadRebel
If its your first time on ETs and your running a radial tire up front
I would start at 20psi and get a feel..
They will move the car around quite a bit as the pressure is dropped. Its something you may want to ease youself into
Phli
Old Feb 24, 2005 | 08:05 PM
Cajundude's Avatar
Cajundude
Thanks for the replies. I've decided just to put one in the hatch wrapped up and one on the pass seat wrapped up and change 'em at the track. I keep thinking about when my buddy did a few 360s at 70 mph for hitting a puddle when he had his on.
Yes, I've got my best times in the right lane at HRP as well.
Old Feb 24, 2005 | 10:08 PM
SR71's Avatar
SR71
Phli
start high. a little tirespin will save parts. a hard dead hook or wheelhop is what breaks things.
Old Feb 25, 2005 | 09:35 AM
Z06 Steve's Avatar
Z06 Steve
roll thru the water box about 1/2 car away and do the burnout.spin em till you see some smoke.12-16 psi start high and keep dropping psi till you get best 60ft's and top end stability.I highly recommend a line lock as you wont beat on the car as much.
Old Feb 25, 2005 | 10:28 AM
Cajundude's Avatar
Cajundude
Thanks. Weather looks good today so I will definitely be going to the track tonight. Line lock will go in in the next week or so. Wish I had it now.
Old Feb 25, 2005 | 10:53 AM
BLU-BY-U's Avatar
BLU-BY-U
I think I'm coming down there tonight, Cajundude. Look for the blue Z06 with CCW et streets/skinnies and you've probably found me. We usually park towards the back of the pits.
As far as psi, I ran about 16 pounds and cut a 1.51 short time three weeks ago, so thats a good starting point. HRP "usually" is prepped better than most tracks, so I agree with comments on start high psi and work your way down if needed. Slight spin is much better than a dead hook.
Old Feb 25, 2005 | 10:55 AM
Cajundude's Avatar
Cajundude
I'll look for you. I'll be out there around 5:00-5:30. MY with license that says KJUN.
To My first time using ET streets
