Both power windows and turn signals...
Old Feb 24, 2005 | 04:59 PM
TurboLs1's Avatar
TurboLs1
Default Both power windows and turn signals...
Recently both my power windows started to quit working sometimes and wouldnt want to go up, but around the same time the turn signals and hazards started operating about half the time too and the left signal would blink very fast while the right one worked normally (if it worked at all). I replaced the left front bulb as it was blown but it still continued to blink fast when it would actually work. Now the turn signals and hazards dont want to work at all, but the DRL and all other lights still operate normally. I also checked the fuses in the fuse box under the dash on the passenger side and also checked the connections to the BCM to make sure they were free of moisture and clean. I'm not sure if these problems are connected or not. Any other ideas? Anyone's help would be greatly appreciated.
Old Feb 24, 2005 | 05:20 PM
PA_BLUE_C6's Avatar
PA_BLUE_C6
St. Jude Donor '05-'10-'12, '15
Being a newbie myself, I am not sure how much I can help, but I have read here on the forum that ground connections are responsible for some very puzzling and intermittent electrical problems. Just a thought.
lots of luck finding your gremlin
Old Feb 24, 2005 | 08:13 PM
TurboLs1's Avatar
TurboLs1
Thanks for the suggestion...Well, the turn signals mysteriously started working correctly tonight but I am sure they will mess up again soon...still no power windows though...anyone else have any ideas?
To Both power windows and turn signals...
