A4 fill plug location??
Old Feb 25, 2005 | 04:15 PM
6spd89's Avatar
6spd89
Cruise-In II Veteran
Default A4 fill plug location??
98 coupe ,where is the fill plug on the tranny??? Just put in a transgo and cannot locate it! Somebody???
Matt
Old Feb 25, 2005 | 05:49 PM
6spd89's Avatar
6spd89
Default ttt
ttt
Old Feb 25, 2005 | 06:00 PM
IMQUIK's Avatar
IMQUIK
The big plug about halfway up the tranny.
Old Feb 25, 2005 | 06:21 PM
6spd89's Avatar
6spd89
Default ?
Which side pls? Thanks!!
matt
Old Feb 25, 2005 | 07:01 PM
tailights's Avatar
tailights
Default tranny plug
drivers side
Old Feb 25, 2005 | 08:53 PM
6spd89's Avatar
6spd89
Default thanks
thankyou all!!!!!!
Matt
Old Feb 25, 2005 | 09:03 PM
RWhite's Avatar
RWhite
A PITA to check/fill. A lift makes it easy.
Old Feb 26, 2005 | 01:26 AM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
If he just put put in a Transgo kit then he's talking about an automatic and the fill plug is in the side of the tranny pan.
Old Feb 26, 2005 | 09:08 AM
6spd89's Avatar
6spd89
Default fill plug
I drained it from the fill plug then?? Confused?? So i fill it till the fluid comes out the fill hole in the tranny pan w/ the car running? Right? I have the deep sump pan FWIW. Thanks, Matt
Old Feb 26, 2005 | 07:16 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
The procedure for filling/checking the fluid in an automatic transmission is to raise the car so that it's level and start the engine and operate it until the transmission fluid is between 86 and 125 degrees (I'm not 100% sure of that temp range but thats pretty close), then shift the transmission thru each gear pausing for a second or 2 at each detent all the way thru, once back in "park" with the engine still running get under the car and remove the plug in the side of the pan, the fluid level should be even with the bottom of the plug.
Old Feb 26, 2005 | 07:34 PM
6spd89's Avatar
6spd89
Default Cool!
Thanks again!! I put about 3 quarts in today w/ engine off. It ran out of the hole so i stopped. I want to change the fuel filter as well. The tranny was bone dry,I let it drain for a few days so i did not get a bath when i pulled down the pan and valve body. I figured it should have some fluid before i started it back up.
I got to change wires today then had to do WIFE stuff. So,maybe tomorrow i can get that fuel filter off.
Matt
To A4 fill plug location??
