need help removing passenger check valve
Old Feb 26, 2005 | 08:49 PM
Majestic43's Avatar
Majestic43
Default need help removing passenger check valve
i have been getting P1416 codes, so i decided to try the common fix by replacing the passenger check air valve. i managed to pull the intake foward and out of the way, but i still couldnt get the valve removed. i was able to reach it w/ a wrench or pliers, but didnt have enough room to loosen the valve from the pipe. any tips on what i can do to get this thing off? thanks!
Old Feb 26, 2005 | 10:50 PM
jers98vet's Avatar
jers98vet
If you've already got the intake out of the way, might as well disconnect the airtubes from the exhaust manifolds and loosen the 13mm (I think) bolt on the driver side head and remove the whole air assembly. Makes it much easier to work on. Jeremy
