after jump starting my car i am now having trouble getting it into reverse. also it started throwing some map codes. has any one had this happen to them? it is an 04 Z06 with all the bolt ons. i am taking it to the dealer on monday i am just kinda frustrated.
I had the map code and hard reverse thing happen in my camaro awhile back. Check the fuse under the hood for the map/maf sensor because it's probably blown. If I remember right the reverse lockout solonoid or whatever it is is on the same fuse.
So now after replacing that fuse it is considerably easier to shift into reverse? I almost have to use two hands to shift mine into reverse..... I'll bet my fuse is blown too..
