Need Help - Halltech Stinger install
Old Feb 27, 2005 | 03:25 PM
stevzc5's Avatar
stevzc5
Default Need Help - Halltech Stinger install
I'm installing a Halltech Stinger on a 99. Everything is going good, except I can't remove the temperature sensor from the air bridge. It looks like you have to push it through the rubber grommet from the inside. What's the trick without damaging it?
Old Feb 27, 2005 | 03:39 PM
stevzc5's Avatar
stevzc5
Never mind. I finally got mad and gave it a mighty tug from the outside, and it popped out. I think it helped that I used some spit as a lubricant.
Old Feb 27, 2005 | 03:44 PM
usd2sing's Avatar
usd2sing
been there...done that!!!
To Need Help - Halltech Stinger install
