z06 manifolds
i read in hot rod this month when they did theyre cam intake swap on the new c6 in which they tell you the ls6 intake is better than the ls2 intake
in the graphs i notice they swapped the manifolds off the ls2 in favor of ls6 (Z06) manifolds
so i got to tthinking how much more power could you expect to get on a base c5 with z06 manifolds
also anybody got any they want to get rid of
thanks in advance
they do a cam swapon the c6 and at the same time they test intakes as well as manifolds and the results were that the cammed car made more power with the ls6 manifolds and the ls6 intake as opposed to the new ls2 versions of intake and manifold
so basically the ls6 intake and manifolds are superior to the ls2 design
in other words all you guys that wanted to start putting c6 parts on your c5s ls1 or ls6 or better off with the ls6 parts
Ok - you're a tad confused on several points. First: manifolds are found both on the intake and exhaust. There are intake manifolds and exhaust manifolds - your terminology doesn't recognize this. Second: The LS6 intake manifold is indeed superior to the first version of the LS1 intake manifold - but of course, this is negated as of 2001 when all intake manifolds put on corvettes was switched over to the LS6 version. So if you have a 2001 or later C5, you've got the LS6 intake manifold. As for the LS2 intake, initial attempts have proven unsuccessful, but Graham at LPE thinks FAST will be disappointed when everyone realizes that this intake is indeed superior to the LS6 design - but tuning is necessary, and noone can do so yet.
As for the exhaust manifolds on the LS2 - they are worse than the LS6 version due to the fact that the catalysts are crammed up high, very close to the exhaust ports - this doesn't allow for a smooth exhaust flow. The LS6 units are longer, and more closely approximate a header, with the cats mounted underneath the car. If you really want performance though, skip them both, and put on long tube headers, which will blow them both away.
there have been numerous threads talking about the new ls2 intake and how they couldnt wait to bolt it on there ls6 or ls1 motors
just trying to save people some money
but anyways back to the original question will the z06 manifolds bolt up to the factory h-pipe on my c5
yes i know long tubes are better and will outperform them but i can get a set of the z06 manifolds(flow better than stock) for 50 bucks as a set of longtubes is 1000
comparing the 2 (z06 vs longtubes ) i know 40 hp is probable for long tubes where im not sure on z06 (once again better than stock)
so ive basically got 50 bucks vs 1000 bucks minimum
and say presumably 5 hp vs 40hp
you see what im getting at
i dont have the money to spend a grand on headers but i do have 50 bucks
im not asking for suggestions on what to do
what i want to know is
WILL MY FACTORY H-PIPE BOLT UP TO ZO6 MANIFOLDS OR WHAT HAS TO BE DONE TO DO SO AND HOW MUCH GAIN COULD I EXPECT FROM THIS IF ANY
50 bucks plus the price of the gaskets for a few hp is hard to beat plus i like the knowledge of changing them myself anyways
2nd post by gmosley refers to using the same H pipe.
3rd post by gmosley refers to both intake AND exhaust manifolds.
4th post by gmosley was a bunch of gibberish, but I was able to make out something about 50 vs 1000.
Grammar doesn't have to be 100% exact, but English is how we communicate in the U.S. Since we are on a web forum which requires us to write to express ourselves, something that resembles AT LEAST a 3rd grade reading/writing level is important.
I'm really not trying to be an A-hole, but people who expect me to decipher their scrambled run on sentences, etc.. are one of my pet peeves. I don't think it's too much to ask for someone to use at least a couple of the rules that were taught in grade school english to communicate effectively with others.
And yes, the newer exhaust manifolds are better than the older ones
but no where near what a good long tube will give you.
sandstone here you go
jsfjklsdgfljskf fsfdfdkl fdfsjkwcdscfhe uihckdfjm jdhyfisnc k djkf xm jf ihe dcvevkdk ekhksfjscjdhfsj jhfjksdhfsdj djfhjshbsdfhx cdjj begfjkdjdbd
decipher that wizard
if you dont like the way i type dont read it because saying nothing at all contributes the same amount of info that you have submitted on the question already none
thank you
I want to know more about this miss Peabody
And, back on topic, isn't the "H-pipe" the thingy that connects the two sides of the exhaust after the catalytic converters? So, how would I bolt the Z06 exhaust manifolds to that? They would make a hell of a racket going over speed bumps, no?
