I am rebuilding the front end on my 81 Z-28. I have been told that unless I plan on doing alot of road & drag racing, to go with rubber because the poly squeeks alot. I plan on doing weekend cruises & shows. Who has used what, & your advise. thanks
First thing, you're in the Corvette section. As for your question, if you're just doing shows and cruises, who cares? If it was your daily driver, or a race car, then it might matter.
Depends on what's available. I've used several different polies (some plain, others graphite impregnated), custom-machined delrin, and steel. If made so they can be greased all will work without squeaks. I've never had graphite impreg squeak, either. Anything is better than the stock/old rubber stuff, as far as performance--competition or daily driver.
Having driven a bunch of stuff with poly bushings I can tell you that driving the River Road will make you feel like you are in a blender.
NEW rubber on an older car will make a nice difference for you I think.
From: Buy USA products! Check the label! Employ Americans
I've used polyurethane on my street car and couldn't be happier. In the C3 suspension it really tightens things up in spite of the worm & sector steering box. It's no replacement for rack & pinion, but they're a whole lot easier to install. If you assemble them as instructed I don't think you'll have any squeaking problems. I haven't and it's been 13 years!
Check with VB&P, they handle the early Camaros too...
