Nobody Gets It!!!!!!!1 Transmitter Training
Old Mar 4, 2005 | 11:30 AM
tonycorvettehd's Avatar
tonycorvettehd
Default Nobody Gets It!!!!!!!1 Transmitter Training
Transmitter Training Is Not In The Menue..does Anybody Understand?????????????????????????????? ????????????
Old Mar 4, 2005 | 11:37 AM
screw991le's Avatar
screw991le
From: Redsox, Pats, Celts & Bruins !!! Redsox Nation !!!
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
Sounds like you have one of those french vettes, who knows
Old Mar 4, 2005 | 11:56 AM
WolfeBros's Avatar
WolfeBros
St. Jude Donor '05-'06-'10-'11
and your point is ?
Old Mar 4, 2005 | 12:12 PM
Blue Smooth's Avatar
Blue Smooth
WTF?
Old Mar 4, 2005 | 12:14 PM
wamara's Avatar
wamara
Cruise-In II Veteran
Sorry, I'd like to help if I could, but I don't even understand your post, let alone what your problem is....
Old Mar 4, 2005 | 12:15 PM
Ego-Trip's Avatar
Ego-Trip
Senior Member
CI 5-6-7-8 Veteran
That kind of attitude probably isnt the best approach to take when you are asking people for help.
Old Mar 4, 2005 | 12:46 PM
3XBlack6spd's Avatar
3XBlack6spd
use any of the buttons on the DIC And press it until there is a blank screen, Then hold down the Reset Key until it says "fob Training", the press and realease it once......Then follow the instructions, It's easy!
Old Mar 4, 2005 | 01:05 PM
tonycorvettehd
im not being rude,i have written for days about my problem and welcome advise from the experenced,please understand i know how to go thru the program to do this,,understand that the transmitter trainingstep in the program is not there,what im asking is ,anybody experence this b4 or know why its not there??????????????????????????trust me ,im a nice guy and i have had over 40 corvettes in my life ,,i have had 3 c5,,,and this is the best place to look for other people with the knodledge ofcorvettes,,thanks
Old Mar 4, 2005 | 01:06 PM
JoshVette's Avatar
JoshVette
So what's the ultimate goal here?
What's all that do in the end after you follow the instuctions?
Old Mar 4, 2005 | 01:15 PM
intel55's Avatar
intel55
I used to have a handle on life, but it broke.
Old Mar 4, 2005 | 01:39 PM
EHS's Avatar
EHS
tonycorvettehd:
Tell us exactly what it is you've done, and what does or doesn't show up in your menus.
Have you gone into the DIC fob training menu, and if not, why not?
Are you actually trying to train a FOB or two, or just a bit curious?
We're here to help.
Old Mar 4, 2005 | 01:40 PM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
You say the training step is not there...There are two seperate "MODES" that you can put the DIC into...one is a diagnostic mode and it reads from the seperate Modules that are reporting faults.
The "diagnostic display" MODE is entered with the following Procedure:
Turn on the ignition but don't start the engine.
Press the "reset" button to turn off any warning messages
Press and hold "options" and
While holding "options", press "fuel" four times within a 10-Second period.
The Secound "MODE", is a "Training" MODE. Here you can program either your Key FOBs or your Tire Pressure Monitor Sensors.
To match the transmitter to your vehicle:
1. Turn the ingnition key to the ON position
2. Clear any warning messages on the Driver Information Center (DIC) by pressing the RESET button.
3. Press the OPTIONS button on the DIC several times until the blank page is displayed, then press and hold the RESET button for two seconds.
4. When the message FOB TRAINING is displayed, push the RESET button once. The message HOLD LK+UNLK 1ST FOB will be displayed.
5. Press and hold the LOCK and UNLOCK buttons on the transmitter simultaneously for 15 seconds.
6. When a transmitter is learned, the DIC will display FOB LEARNED and then prompt you to learn the next transmitter.
7. Repeat steps 5 and 6 for each additional transmitter.
8. Remove the key from the ignition.
The programmer mode will shut off if:
You don't program any transmitters for two minutes.
You take the key out of the ignition.
You have programmed three transmitters.
Notice.....
You Press the FUEL button when entering the Diagnostic mode......
You press the RESET button to enter the DIC training Mode.....
Good Luck
Old Mar 4, 2005 | 02:12 PM
JoshVette's Avatar
JoshVette
Notice.....
Good Luck
AWESOME!!!...I'm driving the Space Shuttle!!!
Old Mar 4, 2005 | 02:29 PM
tonycorvettehd
Default transmitter training
thanks,sounds like you know what your talking about,,,i went thru the diag mode there were several codes,i reset them,i hope thats ok,,but i still dont get transmitter trainind at the point i should,i only get tire training ,is there a code i can check to see if transmitter training is on or something???????thanks tony
Old Mar 4, 2005 | 02:41 PM
12stepvette
Interesting.....Once you have cleared the screen using the Options button...
then held the Reset button, you should see FOB Training as the first selection.
Pressing the Options button at this point should toggle you between, Fob or Tire training.
When in diagnostic mode, is the car showing any RFA faults??
Old Mar 4, 2005 | 02:49 PM
tonycorvettehd
Default trans training
i steped thrpogh and it shows b0-rfa no codes,,,,i have no codes on everything,,just to refresh ,,i bought this 99 car ,it came with no transmitters ,i got one from ebay and im trying to program it,,like i said when i get to the training section only tire training is there...
Old Mar 4, 2005 | 02:59 PM
12stepvette
I`m Stumped!!!...Either it is a bare bones FRC(Sorry guys, Couldnt help myself!), someone has been in there with a Scanner and removed the option for keyless entry, or the RKE Module is failing.
To Nobody Gets It!!!!!!!1 Transmitter Training
Old Mar 4, 2005 | 03:04 PM
tonycorvettehd
do you know the option for remote access?
Old Mar 4, 2005 | 03:06 PM
12stepvette
Nope...it`s beyond my limited Knowledge, sorry.
Old Mar 4, 2005 | 03:16 PM
tonycorvettehd
thanks alot,,,i think im going take off the door pannel and see if something is unpluged,,someone told me that the recievers are in the doors for the remote access and they may be unpluged or bad??????????thanks
