Damn exedy twin disc
Old Mar 5, 2005 | 07:20 AM
Cunningham Motorsports's Avatar
0Cunningham Motorsports
Former Vendor
Default Damn exedy twin disc
how many of you guys that are running the exedy twin, breaking diffs left and right, on thursday night at the track, i just cracked my case basically in half, the car wouldnt even roll it was locked up, took alot of moving around get it to eventually roll. this my diff i have screwed up i am fed up with it, i thinking of ditching it for a cartek, or maybe that new australian clutch
Old Mar 5, 2005 | 07:47 AM
kumar75150's Avatar
kumar75150
from what I have seen, the twin disk clutches are a nightmare on the driveline because of the way they grab.
I have a friend that broke 2 300m hardened output shafts with the Mcleod Dual and ended up putting a Ram single in his car and no more problems.
Old Mar 5, 2005 | 10:58 AM
Tony Mamo @ AFR's Avatar
0Tony Mamo @ AFR
Former Vendor
ANYONE running an Exedy dual needs to have a DTE strut brace if they ever plan on hitting the track with any type of rubber that actually bites....and drag radials could potentially be worse because they have zero sidewall "wrap".
I've experienced the wrath of the Exedy twin on my own parts firsthand and have shared with you guys my love/hate relationship with this clutch. NOTHING on the planet can shift like it (except for high dollar small diameter racing clutches), but you had better have your driveline in order or look out.
Check out this thread and the previous comments I personally made as well as others....
http://forums.corvetteforum.com/showthread.php?t=994717
Get a rear end brace if you guys plan on hooking with an Exedy....and then the weak link becomes your parts within the rear....and on and on.
Tony M.
Old Mar 5, 2005 | 11:22 AM
DIP51's Avatar
DIP51
2018 C2 of Year Winner
Every chain has a weakest link...and horsepower/torque + traction = finding said link
Old Mar 5, 2005 | 11:43 AM
supercoupe01's Avatar
supercoupe01
I just put the rear end brace on last weekend. Seems like a must for the track. Would much rather increase the chances of breaking an output shaft instead of the rear/ transmission.
Old Mar 5, 2005 | 01:29 PM
90 droptop's Avatar
90 droptop
Ryne, that sucks dude. Give me a call about the DTE strut brace.
Old Mar 5, 2005 | 02:37 PM
vettethret's Avatar
vettethret
I cracked my diff in half and it took my tranny with it. This was on a shift from 1st-2nd on PCH on 20" 305/25/20 CONTI'S!
Old Mar 5, 2005 | 03:00 PM
9899Z06's Avatar
9899Z06
Ryne,the exact thing happened to me last week. It was my first day with exedy twin desk and launched my car at 5000 rpm, had my MT ET streets on that night. Suddenly at the green light i attempted to launch and was surprised why my car did not move at all!! the rear wheels were locked! it was a nightmare! i sure know how it feels. This broke the main shaft and my new rear!
im getting another differential from Phil @ DTE, he also recommends getting the differential strut to avoid this from happening. I really appreciate Phil's effort in working on my new diff.
ebrahim
Old Mar 5, 2005 | 06:41 PM
Former Vendor
yeah i dont know if i am going to stay with this clutch or not, even with a brace i am afraid its going to nuke it again, i just up i didnt break the output shaft of the transmission
Old Mar 5, 2005 | 06:55 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
The clutch didn't break the differential, the diff broke when it twisted under power so installing the brace will fix that and you should be covered ...atleast I haven't heard of anyone breaking differentials with the brace installed
Old Mar 5, 2005 | 07:03 PM
BLOWNZO6's Avatar
BLOWNZO6
Premium Supporting Vendor
I think it is funny that the clutch did EXACTLY what is was supposed to do and you somehow blame it for your diff troubles.
Your driveline issues move from front to back and then inside the rear end when you start improving the weak links. Why go away from the clutch? That will certainly not solve your problem.
The DTE brace is a necessity as Tony stated.. it is SUPER easy to install as well... especially if you have the rear end down.
__________________
EAST COAST SUPERCHARGING SALES AND TECH SUPPORT
WWW.EASTCOASTSUPERCHARGING.COM
Old Mar 5, 2005 | 07:05 PM
9899Z06's Avatar
9899Z06
my diff broke because the clutch brought pressure towards the rear and caused the main shaft to brake into 3 pieces! one of the pieces ended up in the diff! thats what suprised me.
Old Mar 5, 2005 | 07:26 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
The only reason the mainshaft broke is because the differential tried to flex in a rotational plane which put excessive force on the shaft.
Old Mar 5, 2005 | 07:48 PM
GVZO6's Avatar
GVZO6
I do not get it ,alot of people complain about this clutch doing its job ,they invest $1700 and fail to install a $400 dte diff brace .
Old Mar 5, 2005 | 09:07 PM
mdhmi's Avatar
mdhmi
... I haven't heard of anyone breaking differentials with the brace installed ...
Do a search for carnage in the FI section. Diff brace will help but it doesn't cover everything.
Mark
Old Mar 5, 2005 | 09:14 PM
The DBK's Avatar
The DBK
Virtually the same thing happened to my car. Nice clutch, but isn't quite what the forums initially assessed it to be. Great for road driving and presumably road racing, but not a drag clutch. From what I've heard the diff brace isn't enough to assure this won't happen anyways...
Old Mar 5, 2005 | 10:26 PM
kumar75150's Avatar
kumar75150
ya the brace will help a lot but it wont make the rear end bulletproof
To Damn exedy twin disc
Old Mar 6, 2005 | 05:47 AM
vetteamerica's Avatar
vetteamerica
Can someone reply with contact info for DTE? Interested in buying this brace. thanks
Old Mar 6, 2005 | 09:55 AM
9899Z06's Avatar
9899Z06
go to www.dynotech-eng.com everything you need is on their website
Old Mar 6, 2005 | 02:44 PM
Former Vendor
i understand what you are saying, but how hard it hits compared to lets say a ram clutch or whatever, its hard and is not smooth, when i first got this nearly a year ago i thought it would work good for drag racing, i guess i was wrong, i dont think the brace will solve all my issues, the internals of the diff are not effected my the brace so... you get my drift, plus i am not a big baller like most of you guys, i am only 20 , i work on this car all myself, i got this clutch from a shop that owed me money so i got it real cheap, so a 300 dollar brace isnt pocket change to me, and neither is fixing another differential problem.
