How to clean up pistons?
Old Mar 5, 2005 | 06:08 PM
Vette Stripes's Avatar
0Vette Stripes
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08
Default How to clean up pistons?
I have removed the heads to upgrade to stage 3 and see some carbon on top of those pistons.
I have tried to clean them but I could only clean a bit.
Any trick?
Thanks,
-Mike
Old Mar 5, 2005 | 06:33 PM
ROD BROWN's Avatar
ROD BROWN
Default Clean the pistons
At all parts houses they sell a scraper with about 2-2.5" scraping surface.They cost about $5-10.pick one up and scrape the top of the piston.Turn the crank shaft until that particular piston comes all the way up .Makes it easier to clean the top of the piston and clean up isn't a hassle either.
Old Mar 5, 2005 | 06:59 PM
Patches's Avatar
Patches
A buddy and I used one-sided razor blades with the piston at TDC. Just takes a few minutes per piston and they come out very clean.
Old Mar 5, 2005 | 07:31 PM
0Vette Stripes
Former Vendor
Thanks y'all ...
I got ice scaper from Pep boys but just worry to scratch the cylinder walls ... I guess not.
-Mike
Old Mar 5, 2005 | 08:39 PM
Monster231's Avatar
Monster231
try a top cleaner, that you would normally take in through your intake
Old Mar 5, 2005 | 08:44 PM
pdd000's Avatar
pdd000
i used a razor and wd40 for the piston tops. i cleaned the block with wd40 also. worked great
Old Mar 5, 2005 | 08:52 PM
C5Jim's Avatar
C5Jim
Scotch Brite is the best for this . It will not harm the aluminum.
You could use it with WD-40 or brake cleaner.
Old Mar 7, 2005 | 12:39 PM
bradfordjr's Avatar
bradfordjr
Any trick?
Thanks,
-Mike
I installed the ECS Alky Injection Kit...it keeps my pistons "squeeky" clean.
Jim Bradford
Old Mar 7, 2005 | 06:14 PM
Special K's Avatar
Special K
Any trick?
Thanks,
-Mike
Mike, I'm just curious. What thermostat were you running? Thanks.
Bob
To How to clean up pistons?
