Hypertech 160 or 178 degree T-Stat?
Old Mar 5, 2005 | 10:09 PM
Eskridge's Avatar
Eskridge
Default Hypertech 160 or 178 degree T-Stat?
I am going to install a few performance enhancements on my 98 LS1, including the Hypertech Program. What is the best T-Stat to use, 160 or 180 degrees?
~Mike
Old Mar 6, 2005 | 06:22 AM
pewter99's Avatar
pewter99
St. Jude 15 Year Donor
Pilot of Beer Force 1
Tampa Regional Coordinator
CI 4-5-6-7-8 Veteran
Organizer St. Jude Fundraiser
I believe in the Beer Fairy
Ok which is it?? Title says 160 or 178..thread says 160 or 180....personally I think 178 should be as low as you go..
Old Mar 6, 2005 | 07:12 AM
Special K's Avatar
Special K
~Mike
In Florida I run a 160 with lowered fan temps. Car stays around 180.
Bob
Old Mar 6, 2005 | 07:17 AM
lar66BB's Avatar
lar66BB
The thermostat only controls when the water reaches the set temp. to
open. It does not control the max temp. it will run. The fans temp
setting controls that temp. Factory fan settings are pretty high,
I do not remember exactly but I think around 225-230. There are
various way to change this. From a fan controller that mounts in
the engine bay, to reprogram of the computer. I have mine programmed
at 190 and this works very well. The low temp therm. is good that
the water get to 180 opens then the fans will keep it at 190 or what
ever you have programmed it. I like the 178-180 range. My personal
opinion is 160 is too cool, and if you live in a cold climate really
not the way to go.
To Hypertech 160 or 178 degree T-Stat?
