Difference in Wheel Offset w/identical wheels?
Old Mar 6, 2005 | 01:02 PM
03LingenfelterC5's Avatar
03LingenfelterC5
Default Difference in Wheel Offset w/identical wheels?
Well, I am stoked to have the vette back from Lingenfelter, and I just mounted the wheel and tire set that have been prepared to handle the added HP. I purchased Chrome five spoke repros from Bob at House of Wheels. The wheels are all stamped with the following:
Front: 9.5" x 17" 54mm offset
Rear: 10.5" x 18" 58mm offset
The wheels measure perfectly and I love the OEM 5 spoke look in Z06 sizing. They are perfect for the Nitto R2 305 rears and 275 fronts and they mounted and balanced beautifully. Here is the really weird thing, when I take a strait edge and hold it up against the tire vertically right over the center of the wheel on the rears, the offsets measure perfectly from the hub. But when I measure the distance from the strait edge to the fender, it is about 5mm out on the driver side, but only 1-2mm out on the passenger side. The passenger side looks flush, the dirver side looks just a little further out, if you look really close. You don't notice it on the walk around, just under close scrutiny.
Any one have this happen? I just cannot figure out why they are not the same. The car has never been damaged. Thanks for any help or advice you can offer.
BK
Old Mar 6, 2005 | 03:32 PM
Wah's Avatar
Wah
Measuring against body line is not the most accurate method. There is some manufacturing tolerance and being a GM with plastic body panels, I'm not surprised the discrepancy is that much. If you want, measure the wheels against a point in the chassis/suspension.
Old Mar 6, 2005 | 03:49 PM
Y2Kvert4me's Avatar
Y2Kvert4me
CI 6-7-8-9-10 Veteran
St. Jude Donor '03
The above sounds like a possibility,
Also, have you driven the car at all? If it just came off the jack, you need to drive it a bit to get things settled back into place.
If you have driven it, having your alignment checked would be the next step. A slight difference in camber degree adjustment can easily make that 2-3mm difference you are seeing at the top of the tire.
To Difference in Wheel Offset w/identical wheels?
