Fast blinking turn signal
Mar 6, 2005 | 07:28 PM
I test drove an 01 MN6 today whose left turn signal blinked twice as fast as the other. Whats that all about?? Anyone ever heard of that and how do you fix it?
Mar 6, 2005 | 07:31 PM
Almost every vehicle made does that when a bulb is out.
Mar 6, 2005 | 07:32 PM
simple fix. Its simply a relay going bad.
CI 5-6-7-8-9-10 Veteran
St. Jude Donor '07-'08
probably a burnt out bulb.
Chris
Mar 6, 2005 | 07:57 PM
St. Jude Contributor
Bulb burned out is the most likely problem.
Mar 6, 2005 | 07:59 PM
St. Jude Donor '03
Quote:
bulbs are the culprit 99% of the time
Mar 6, 2005 | 08:05 PM
Quote:
My rear left blinkers and brake light dont work, but the running lights DOOOO, i changed the bulbs but still dont work
So what relay are you talking about???
Its a NIGHTMARE My REAR BLINKER AND BRAKE LIGHT DONT WORK on DRIVERS SIDE but the passengers side works fine
help me out
Mar 6, 2005 | 08:10 PM
help me out
I had to replace the actual socket the bulb goes into one time because it was blinking fast, but the bulb was ok.
Mar 6, 2005 | 08:24 PM
St. Jude Donor '03-'26
You might be low on blinker fluid. Did you check the dip stick?
Mar 6, 2005 | 08:32 PM
Quote:
Don't they have a special on this on ebay?
Mar 6, 2005 | 09:00 PM
most likely a bulb
Mar 6, 2005 | 10:05 PM
Change the bulb. If you look at it, it should be out.
Mar 6, 2005 | 10:09 PM
also check the filter...
sorry, i couldnt resist...
Mar 7, 2005 | 11:51 AM
nice
I found the dipstick right next to the kanooter valve...
2002 ,
2004 ,
2005 ,
blinker ,
blinking ,
c5 ,
corvette ,
fast ,
faster ,
flickering ,
left ,
light ,
rapid ,
rapidly ,
signal ,
turn
