90mm T/b Need Help!!!!
Old Mar 6, 2005 | 10:21 PM
hydfixer1's Avatar
hydfixer1
Default 90mm T/b Need Help!!!!
Who makes the best 90mm T/B now? I have a old Williams? about 9 months old, and was never able to get the idle to stablize. It idles at 2100rpm till the mph on the HUD reads 0 than drops to 950rpm. Two differnt tuners both say it might be the t/b. Its on a 432 CID with a fast intake and a T-REX cam 110 lsa. Any ideas? I tried the LS1 fourms but since they use a cable they don't have this problem. Thanks.
Old Mar 6, 2005 | 10:58 PM
SinCity-Z's Avatar
SinCity-Z
Use an LS2 TB it is 90mm and works just fine on m Z
Monty
Old Mar 7, 2005 | 08:20 AM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Nick Williams has a new improved version of the 90mm T/B that is supposed to have taken care of the issues you mentioned.
LG Motorsports sells them: http://www.lgmotorsports.com/shop/pr...e1dd8ca6dcd515
Old Mar 7, 2005 | 08:29 AM
see5's Avatar
see5
Monty
I agree, and relatively cheap too.
Old Mar 7, 2005 | 09:48 AM
NEPTUNEBILL's Avatar
NEPTUNEBILL
Old Mar 7, 2005 | 01:38 PM
Bink's Avatar
Bink
Cruise-In V Veteran
St. Jude Donor '09
Just contact Nick or gojo. See if they can upgrade your existing NW 90 mm TB?
Old Mar 7, 2005 | 01:45 PM
90 droptop's Avatar
90 droptop
I spoke with Nick last week, he said he was doing the update for free.
Call him and send it in.
Old Mar 7, 2005 | 01:50 PM
Fast one's Avatar
Fast one
I have a new 90 mm from LG and it has a screw adjustment; if the adjustment is off the engine won't run right. The screw adjusts the throttle blade opening and the resulting sensor value. The allen set screw is on the motor side and has another allen set screw to lock the first.
Old Mar 7, 2005 | 03:57 PM
hydfixer1's Avatar
hydfixer1
Do you have his number ?
Old Mar 7, 2005 | 07:34 PM
gojo's Avatar
gojo
You have mail.
Old Mar 7, 2005 | 07:35 PM
gojo's Avatar
gojo
It's pre-set. Best to leave it be.
To 90mm T/b Need Help!!!!
