Hey Guys Thanks For The Help!!! Just Got Front End Tore Down But Need To Know What Is Best Spring Compressor Tool To Use On All Springs With Heads In The Car. I Am Doing Cam Swap Only And Am Concerned About Spring Tool Clearance With Fire Wall. In Addition Can I Reuse The Crank Bolt....i Used My Imact To Remove....any Other Tips You Guys Found On The Swap That Might Be Helpful....thanks Kevin
Do not reuse your crank bolt. I would suggest using a longer version of the crank bolt to get the pulley back on. I didn't and I messed up the first few threads in the crank. If I ever do a cam swap again, I plan on using the GM tool to seat the pulley and pinning the crank so it won't come off. Using a bolt to seat the pulley is not the best method as is puts a lot of stress on the threads.
I went to NAPA and got their spring comp. It's a little hand held screw type. I have done 3 springs swaps with it, it works great and it's only $30. Do you have the air hose and compr. to hold the valves up while changing springs?
yes i have a compressor but was going to bring each piston up 2 at a time to make work. with the napa spring compressor- was there enough clearance on the back cylinders and the firewall. also who sell the longer bolt to get dampner on...thanks kevin
Plenty of room. I would use the comp. air to hold the valves up. It can be PITA trying keep the valve up, compress the springs and put the locks on. JMO
who sell the longer bolt...anybody and how do you lock the flexplate with the a4 or has anybody used a regulated impact to put a new stock bolt back on.....bottom line how critical is this issue....thanks kevin.
