Help deciphering error codes...
Old Mar 10, 2005 | 11:42 PM
MacGuru's Avatar
MacGuru
5th Gear
Default Help deciphering error codes...
ok guys, here's what I have. 1997 C5 35k miles. All stock, no mods ever. Car was mostly kept in a garage over the last few years.
My question is, can someone help me undetand what's going on. From what I can tell, I have a few problems. Here's a list of DIC error codes. Any help is gratly appreciated.
Thanks. -Michael
1997 C5 Corvette
DIC codes pulled 3/10/05
10 PCM4
PO461HC
P0461 Fuel Level Sensor 1 Circuit Performance
PO463HC
P0463 Fuel Level Sensor 1 Circuit High Voltage
P1518H
P1518 PCM to TAC Module Serial Data Circuit
P1571H
P1571 ASR Desired Torque
28TCS-1278H
C1278H
C1278 TCS Temporarily Inhibited By PCM
80U1016H
80-Radio - Radio Not Found
AO-LDCM
A0-LDCM - Left Door Control Module
B2282H
B2282 Battery #1 Fault
B2284H
B2284 Battery #2 Fault
U1064H
U1064 Loss of Communication with BCM
AI-RDCM
B2283H
B2283 Battery #1 Fault
B2285H
B2285 Battery #2 Fault
U1255H
U1255 Serial Data Line Malfunction
U1064H
U1016H
U1016 Loss of Communication with PCM
U1096H
U1096 Loss of Communication with IPC
Old Mar 10, 2005 | 11:45 PM
MacGuru's Avatar
MacGuru
5th Gear
Also, the car runs fine. Just wanted to see if I can fix the source of the problem. I would hate to get stranded...
Old Mar 10, 2005 | 11:57 PM
NOT-MEE's Avatar
NOT-MEE
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06-'07
check battery for corrosion reset all codes. Look for water on floor and battery leaking on pcm. The one's with the c are the ones to be concerned about.
Old Mar 11, 2005 | 01:43 AM
IllinoisCorvette's Avatar
IllinoisCorvette
Old Mar 11, 2005 | 10:34 AM
MacGuru's Avatar
MacGuru
5th Gear
Thanks. I'll start there. What about the TAC module? Is this one of my problems?
Old Mar 11, 2005 | 11:07 AM
MacGuru's Avatar
MacGuru
5th Gear
Should I replace the fuel level sensor too? How much will this cost? I contacted Bob @ Fichtner Chevrolet and he has the TAC module for $207. My thinking is to replace both! Any suggestions? Thanks in advance.
Old Mar 11, 2005 | 06:47 PM
runamuk's Avatar
runamuk
Cruise-In V Veteran
St. Jude Donor '04
All of your codes are followed by an "H" which means they are history codes and are no longer faulting, reset them and don't worry.
Now for the current fault p0461 and p0463, do you have fuel gauge problems?
what type of gas do you use?
Old Mar 11, 2005 | 06:54 PM
LoneStarFRC's Avatar
LoneStarFRC
You also may need to take a serious look at all you grounds and/or your battery.
BTW, the U1016H, U1064H and U1096H codes are extremely common and unless you are experiencing a specific problem with your RFA system, ignore all three. Lot's of folks here have had the same experience. I've experienced these three popping up from time to time for approx 5-6 years.
The advice regarding checking for water/moisture on your BCM is also good too. HTH
Robert
To Help deciphering error codes...
