What should batt volts read before start
Old Mar 12, 2005 | 06:01 PM
lottavettes's Avatar
lottavettes
Default What should batt volts read before start
Should it be 12 or more? If Im at 11.5 do I think about a new battery?
Old Mar 12, 2005 | 06:05 PM
babala65's Avatar
babala65
Yes if its under 12 volts you have a bad battery. A 6 cell battery should have A min. of 2.2 volts per cell.
Old Mar 12, 2005 | 06:13 PM
BEEN THERE's Avatar
BEEN THERE
Old Mar 12, 2005 | 09:57 PM
*C7*'s Avatar
*C7*
St. Jude Donor 05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17
I would guess you have no problem. If you are reading the voltage from the DIC, I don't think it is real accurate as it is for reference only. I checked my every day driver for you which has a Optima red top and it read 11.8 volts on the DIC and checked with a accurate digital volt meter at the battery to be 12.1 volts. I will go on record that NO batt. will read 13.2 volts!!!
Old Mar 12, 2005 | 10:21 PM
TEXHAWK0's Avatar
TEXHAWK0
I agree, you need to check the voltage at the battery terminals with a good voltmeter.
I also see a lower reading on the DIC and just use that for reference. If you have at least 11.5 on the DIC, you should have at least 12 volts at the battery.
Old Mar 12, 2005 | 10:23 PM
MY1STPEWTER's Avatar
MY1STPEWTER
If your car is starting good, and there is no weird electricial things going on I'd say your good. Just my opinion.
Old Mar 12, 2005 | 11:17 PM
12stepvette's Avatar
12stepvette
St. Jude Donor '03-'04-'05-'06-'07
While the car is running......With a good Meter, Read Voltage at the Battery and Compare to DIC.
Old Mar 13, 2005 | 08:43 AM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I was at 10.5 volts the other day on the DIC, and it started you. It have been sitting for a week. Y2K OEM battery
To What should batt volts read before start
