audio problems
Old Mar 13, 2005 | 04:48 PM
corvettefreak16's Avatar
corvettefreak16
Default audio problems
The driver side rear speaker makes a humming noise. what is the cause of this and how do i fix it?
Old Mar 13, 2005 | 04:55 PM
simpleman68's Avatar
simpleman68
Not sure what "hum" is exactly. Vibration on the door panel somewhere, or does the speaker make the noise?
If the door vibrates, there is a lot of loose stuff inside these door panels that can be snugged up that vibrates when the woofs hit lows.
If the speaker is humming, you may have a loose connection at the speaker, bad ground in the wiring harness, or the head unit.
You can check the audio section of this Forum for more specifics.
Scott
Old Mar 13, 2005 | 05:00 PM
corvettefreak16
Its both i have rattleing in the door and i have a humming noise coming from the speaker.
To audio problems
