Which springs?
Old Mar 15, 2005 | 12:36 AM
TurboLs1's Avatar
TurboLs1
Default Which springs?
I am buying a G5x3 cam and am wondering what valvetrain components I need to replace to run this cam? Which springs will fit on a stock head and work with this cam? Do the lifters and pushrods need to be replaced as well? Just trying to get multiple opinions. Thank-you for everyones help in advance.
Old Mar 15, 2005 | 02:57 AM
Mitch C's Avatar
Mitch C
If cost is no object the Comp 921 kit has springs, seats, and ti retainers for a little over $500.00. The 921s are good to .650 lift.
Patroit Gold or PRC spring kits go for about $300.00 and are also excellent springs to use with the G5X3. The Golds are good to .650 lift the PRCs are good to .660 lift. All of the springs mentioned drop right into the stock spring pocket. You should also invest in a set of moly push rods. You can use your stock lifters.
Old Mar 15, 2005 | 10:44 AM
TurboLs1's Avatar
TurboLs1
Thanks for the suggestion.
To Which springs?
