Which Injectors???
Old Mar 15, 2005 | 04:21 AM
Ben01C5's Avatar
Ben01C5
Default Which Injectors???
I have been looking for injectors, and dont know which ones to buy. I know tons of people go with the SVO 30lb ers, but I have also seen the Delphi 32/37's coming up more often.
I can get the SVO's from Steeda for about $250, and can get the Delphi's for about $240.
Is one really better then the other? I believe the Delphi's a disc instead of pintle.
Which would be the better choice?
Ben
Old Mar 16, 2005 | 03:35 AM
Ben01C5's Avatar
Ben01C5
Anyone???
TTT
Old Mar 16, 2005 | 07:50 AM
see5's Avatar
see5
Watch out for the fit into the manifold. I am aware some of the Racetronixs are a very loose fit. If you compare drawings you will see why.
The SVOs fit like stock.
Old Mar 16, 2005 | 10:21 AM
plaster's Avatar
plaster
I am going through this right now. I was interested in Delphi's because of there disc (supposedly better) design. I was told to stick with SVO's because of the wiring - the other ones do not have the same current or impedence or something.
Old Mar 16, 2005 | 11:56 AM
Ben01C5's Avatar
Ben01C5
Interesting!!! Looks like I will play it safe and order the SVO 30's.
Now I just need to find the best price on the LS-2 timing chain set and I will be good to go.
Old Mar 16, 2005 | 12:05 PM
Ikester's Avatar
Ikester
CI 6-7-8-9 Veteran
St. Jude Donor '08-'09
Go with Rollmaster duals. No clearance problems with ASP pulley.
LS2 chain doesnt even come with new gears. just a single chain.
Old Mar 16, 2005 | 12:06 PM
see5's Avatar
see5
Chain is ~$30 thru the Forum dealers.
Old Mar 17, 2005 | 11:01 AM
Ben01C5's Avatar
Ben01C5
I am not running a pulley, so clearance won't be a problem.
To Which Injectors???
