i need the some pics of that RPM trans/diff brace, i am in the market and its either this one or DTE's, i have seen the dte's, but not the RPMs, also whats the website to that company
My vote goes to DTE, mine is being installed as we speak along with a DTE stage II 4.10 diff. I looked at both braces and IMO DTE's appears to provide more support (not bashing RPM). Either way you go, DTE or RPM you won't go wrong.
You got my vote for DTE. I've got one and I researched both of them. DTE provides greater support.
A few hundred passes on my car (on sticky tires/5k+ launches) with the RPM unit and no breakage. So I've got a unit that works AND is several pounds lighter.
A few hundred passes on my car (on sticky tires/5k+ launches) with the RPM unit and no breakage. So I've got a unit that works AND is several pounds lighter than the DTE unit.
Yep, both apparently are very good products. I will say that just looking at the RPM design, it seems much simpler, which should equate to an easier install. But who am I to talk about wrenching anything anyway, right ECS?
Has there ever been a failure with the RPM strut/brace?? Does anyone know of a single failure???TIA.
I am always talking to the guys (and gal ) over at RPM. I would have heard about any failures. I don't know 100% for sure, but I would bet there haven't been any.
well i went with the DTE brace it just looks stronger to me, i mean the RPM brace might be all that i need, but i tend to break things that usually dont break, so i want all the insurance i can get, plus the RPM brace is 30 dollars more, for less of a product doesnt make sense to me
That's surprising that the RPM brace is more expensive than the DTE brace. I wonder what the rationale behind that is.
Mark
You get what you pay for?
J/k
I don't know. Why is there $100 difference in fares between airlines from DFW to Orlando? (I recently went through that.)
Some airlines are able to offer a better rate based on cargo business offsetting the cost of the flight. Also time of day and day of week is a big factor. Perhaps one of the airlines has a hub in Orlando. Etc, etc.
