tire sensors
Old Mar 16, 2005 | 09:07 AM
gregk1's Avatar
gregk1
Default tire sensors
I had my new wheels put on my car and one sensor reeds XXX do I need to retrain them it is a 98 c5 all the rest work but the right front les schwab did the tire work could they have damaged on of ny sensors???
Old Mar 16, 2005 | 09:13 AM
Ragtop_Rob's Avatar
Ragtop_Rob
St. Jude Donor '17
Just retrain them - it is VERY easy and then you will know if it is the sensor or not.
Here is the link how - just in case;
https://www.corvetteforum.com/techti...D=77&TopicID=1
Old Mar 16, 2005 | 09:38 AM
DidntSettle's Avatar
DidntSettle
From: Manchester - Political correctness is tyranny with manners.
We have a '98 also. We installed new tires, and then a month later, new wheels with tire swap. We had no trouble, but I know that the time is near because the batteries are probably just about shot. Yours may be about to die as well.
Old Mar 16, 2005 | 11:19 AM
gregk1's Avatar
gregk1
Well I did the reprogram thing and everything worked right, but the sensor still doesn't work, I just get a blank on the right front, you say batterys?? what kind of batterys?? I supose they are GM at $25 each or can you get them at raido shack?? I watched the KID do my tire work and he was Yankn and Cranken on them I could not watch anymore and went and sat down!! I have read that you put one bead of the tire on and then the sensor then finish the top bead then air the tire True?? this KID put the sensor on first then the tire shoving one bead past the sensor good? or not good?? thanks for the help >>>Greg
Old Mar 16, 2005 | 01:10 PM
DidntSettle
I wish they were $25. You have to replace the sensor and at GM they quoted me $139....each. But there are places that sell them cheaper. Do a search on the forum on wheel sensors, or TPS and see what you find. There is a vendor (name escapes me) that has had some luck replacing the battery, but they are "potted" in, and the sensor is very difficult to dig out without damaging the sensor. Good luck.
Old Mar 16, 2005 | 03:04 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
Did you drive it after you reprogrammed? They need 15 or 20 minutes of driving before they start reporting in.
Old Mar 16, 2005 | 06:08 PM
BiggieBoy's Avatar
BiggieBoy
St. Jude Donor '06-'07
This is who you are looking for http://www.nericreations.com/
To tire sensors
