Ride height
Old Mar 18, 2005 | 05:09 PM
TAGVETTE's Avatar
TAGVETTE
Default Ride height
My friend has a 04 MN6 with the selectible suspension. Mine is a 02 MN6 without. Mine seems to ride just a bit lower than his. I know that my car has not been fooled with as far as suspension goes. Since his has the selectible suspension, does this matter as far as ride height? Can it be lowered?
Old Mar 18, 2005 | 05:26 PM
leaftye's Avatar
leaftye
Both cars can be lowered. The suspension shouldn't really matter, although spring rates and the weight of the car can affect ride height, even if the adjustments are the same. His spring might also be curved a little more than your spring. Either way, you could lower it far enough to scrape ants off the road if you really wanted to...flatter springs, cut bushings and 3R uprights would definitely do that!
