Wheel Spacers
Mar 18, 2005 | 05:46 PM
Wheel Spacers
Just bought C6 Wheels for my FRC. Heard the back wheels need spacers. Anybody know how thick and where to get them?
Also, can I get the speedo adjusted for the larger wheels?
Mar 18, 2005 | 06:06 PM
From: Buy USA products! Check the label! Employ Americans
CCW can make a nice spacer
Mar 19, 2005 | 10:49 AM
Mar 19, 2005 | 11:02 AM
Check out the only man banned from racing for going too fast.
fred@wheeladapter.com
Vinci tuner can adjust speedo for whee/tire size. Be carefull of Active handling issues when overall front/back tire dimensions get far apart.
Mar 19, 2005 | 10:47 PM
If spacers are needed, I'd expect whomever you got the wheels from to have told you and offered to supply them! Good grief.
All the best.
Mar 20, 2005 | 12:05 AM
St. Jude Donor '06
If those are OEM C6 wheels, I believe that the spacing difference is 12mm (just under .5"). To verify, compare your old vs new, using the technique shown
here . Also ensure that any spacer you get is hub-centric (see below, right):
For where to buy, check the forum vendor sites and/or Google for
Corvette wheel spacers .
As for the speedo adjustment, any of the popular tuning s/w or handheld tuners can accomodate that. You can predict the change by comparing old vs new tire OD with either of these tire calculators:
http://www.discounttire.com/dtc/broc...o/tireMath.jsp
http://www.1010tires.com/TireSizeCalculator.asp
Mar 20, 2005 | 02:20 AM
Quote:
They make nice wheels to go with them too!
