My current Mod thoughts....
Old Mar 18, 2005 | 05:52 PM
1999 Vette's Avatar
1999 Vette
Default My current Mod thoughts....
First, my tech guy said the SC would be about $10,000. I thought around $6,000, so the SC is a little further away than I thought.
So...in the meantime, I was thinking gear change to 3.42 (I think I have 3.15 as the service parts tag in the glove box says G92...and I believe in another thread thats what G92 means...3.15 gears....I have a '99 AT).
My tech guy said this will yield about 40 HP. He also said the ride will be a lot stiffer. What is exactly does that mean? As an everyday driver will I be bothered by this?
If I have a $3000-$4000 budget, what else should I add?
Lastly, In my first ever post, I stated that my car dyno'd low (270). My tech guy said he is doing something to reset the computer with some software program from Star that should hopefully take care of this lack of HP (having dyno'd the car himself, he did feel that is was low). Anyone hear of doing something like this?
Old Mar 18, 2005 | 06:00 PM
99SilverC5Coupe's Avatar
99SilverC5Coupe
Changing gears won't add horsepower....but it will feel faster and accelerate quicker....you will need to have your shift points reprogrammed... as far as the ride being stiffer...no way...your changing gear ratio not suspension componets...you may also want to consider a performance torque converter and some LT headers...you may also consider changing tech guys... if he really said gears will give you 40hp and a stiffer ride...
Old Mar 18, 2005 | 06:03 PM
Jeff Jeff's Avatar
Jeff Jeff
Gears will help make it feel faster. Since you have an auto, you will want to do a shift kit and a torque converter. Hopefully someone that is more familiar with autos will chime in.
If you don't have an air intake, do that first. They make a big difference.
As far as the tuning, I have never heard of star. Most dyno shops that tune vettes use LS1 edit. Tuning won't do much for a stock engine. I don't feel it is worthwhile until you go past the bolt ons (unless autos require it for TC/gears).
Old Mar 18, 2005 | 06:13 PM
1999 Vette's Avatar
1999 Vette
Thanks for the feedback....so is the power by changing gears an illusion? It will seem like I am going faster but actually not? (sorry I'm confused).
Also, I thought after reading many posts on gears that this was a good thing to do for better acceleration!
By the way, I do have an air intake by K&N. Truthfully, I haven't seen any difference with it.
Old Mar 18, 2005 | 10:36 PM
GreensKeeperNJ's Avatar
GreensKeeperNJ
gears will make the car quicker not faster, quicker acceleration 0 to 60 will improve. 1 turn of the drive shaft 3.42 turns of the wheels. hope this helps. Its good seat of the pants type power.
Old Mar 18, 2005 | 11:58 PM
fredsvette2001's Avatar
fredsvette2001
I agree with 99SilverC5Coupe regarding your tech guy. You might want to look elsewhere. If I had a stock automatic and $4k to spend, I would do the following:
Vararam VR-2B Intake - $380 (self installation) - this one's a no brainer and will easily get you 10rwhp over the stock airbox.
170 degree stat - $70 (self installation) - worth a few horsepower and not "too cold". Not a big power gainer, but it's cheap.
Pick up a slightly used 3.42 rear and have it installed approx $1200 ($600 for rear, $600 for install). As stated above, This will increase your rate of acceleration, although I think it's the other way around regarding drive shaft to tire turns (3.42 rear will turn the tire one revolution for every 3.42 turns of the driveshaft).
Cam installation with custom tune approx $1900 (stock exhaust is slightly restrictive, but even a mild cam with dynotune should get you 40rwhp)
The mods above come to around $3550. Take the $450 and save up for a Torque converter. Installation/tuning - approx $1,300
Old Mar 19, 2005 | 12:54 AM
loudsam's Avatar
loudsam
I would say, do longtube headers, and upgrade your air intake. Or, save another 2500.00 to go along with the 4000. you already have and do heads/cam. The only thing about heads and cam, would be you would probably want a higher stall torque converter. In which case you might also think about the converter, gears, and longtubes/air intake now, and save the money to later do the heads/cam.
Old Mar 19, 2005 | 01:17 AM
Mitch C's Avatar
Mitch C
Gears and a high stall T/C will make your car much quicker. IMO they are a must on an A4 if you want great performance.
Old Mar 19, 2005 | 02:41 AM
WALLstAL's Avatar
WALLstAL
St. Jude Donor '05
Just one question or two. Is your tuner a Corvette Specalist and who??
Old Mar 19, 2005 | 10:17 AM
1999 Vette's Avatar
1999 Vette
Is he a corvette specialist? If you mean someone certified to work on vette's I'd say no. I went to this person based on referrals from other vette owners who have had good experience and he has worked on many other vettes. (but I know that doesn't mean he's doing it right) I will look around.
Thanks for the help!
PS are there any negatives to the higher gears (3.42) I should be aware of?
Old Mar 19, 2005 | 11:31 AM
Chrispy's Avatar
Chrispy
You need a new tech!!
Get a good torque converter, headers, catback, intake, thermostat and tuning. You should run mid to low 12's easily at 110-112mph.
Old Mar 19, 2005 | 11:39 AM
sams96's Avatar
sams96
Ask yourself how fast you want to go. I went 12.4 @114 mph with a full exhaust with a stock 3.15 rear and a stock converter. If you want to go into the 11's then you need a converter and a bigger gear.
Old Mar 19, 2005 | 05:35 PM
16Again's Avatar
16Again
St. Jude Donor '07-'12, '20
Some real good advice above. My advice....Check my signature
Bob
To My current Mod thoughts....
