LS1 Oil Pump Recommendations?
Old Mar 19, 2005 | 11:22 AM
Ex_F-Body_Enthusiast's Avatar
Default LS1 Oil Pump Recommendations?
I'm collecting parts for a head and cam swap, and since the oil pump gets touched, I'd like to replace it with an upgraded version that's blueprinted and possibly ported. Any suggestions would be greatly appreciated! TIA!
Old Mar 19, 2005 | 01:13 PM
Ben01C5's Avatar
Ben01C5
Check with the vendors, SDPC has ported ones I believe.
Old Mar 19, 2005 | 02:06 PM
jers98vet's Avatar
jers98vet
I bought a ported ls6 pump from Texas Speed
Old Mar 19, 2005 | 02:09 PM
leaftye's Avatar
leaftye
No one really blueprints it. They just take it apart, port it a little, and put it back together. If you have a dremel, spend $20 on Handzel's book, and $80 on a new pump from www.gmpartsdirect.com and do it yourself.
Old Mar 19, 2005 | 02:40 PM
Good info as always! Thanks!
Old Mar 19, 2005 | 02:56 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Mti
Old Mar 19, 2005 | 07:40 PM
Default AP Engineering Oil Pump?
Any experience with the oil pump from APE?
http://www.automotiveperformance.net/products.htm
Looks trick; and not much more $ than the others. . .
Old Mar 19, 2005 | 08:33 PM
blktie8's Avatar
blktie8
Default Mine is a Katech
Katech
Old Mar 19, 2005 | 09:13 PM
phils C5 vette's Avatar
phils C5 vette
St. Jude Donor '12-'13-'14
I got mine from Texas speed
I push 15 pounds more pressure when I get on it.
idle is 45 pounds
Old Mar 19, 2005 | 09:17 PM
99 vett babycar's Avatar
99 vett babycar
idle is 45 pounds
Old Mar 19, 2005 | 09:39 PM
loudsam's Avatar
loudsam
[QUOTE=phils C5 vette]I got mine from Texas speed
idle is 45 pounds[/Q
I get about 15 pounds more preasure at Idle, usually around 60 psi at cruise. Mine is from LPE. I was impressed with the preasure, I think it's well worth it!
Old Mar 20, 2005 | 02:03 AM
leaftye's Avatar
leaftye
You can easily shim the pump yourself as well...
To LS1 Oil Pump Recommendations?
