fuel pump
Old Mar 20, 2005 | 08:43 AM
kosc01's Avatar
kosc01
2nd Gear
Default fuel pump
Where and how do u get to the fuel pump plug on the aux.fuel pump. I had a new fuel pump put on and now the gas guage only goes to a 1/2 tank and I run out of gas after 12 gal. Installer is to far away I had it put in on vac. Thanks for the help.
Old Mar 20, 2005 | 05:53 PM
TurboLs1's Avatar
TurboLs1
Just trying to help out as I dont know for sure, but I think if you pull off the passenger rear wheel it is at the front of the wheel well behind a sheetmetal cover. You will be able to see a little bit of it as the cover extends a little past the wheel well lining. Hope this helps and hopefully someone with some knowledge in this area will confirm or correct me.
Old Mar 20, 2005 | 06:11 PM
servohead's Avatar
servohead
It depends on what year his corvette is. I believe 2001 and up has the updated style tanks where the pumps and sending units are on top of the tank.
Old Mar 20, 2005 | 07:41 PM
TurboLs1's Avatar
TurboLs1
Mine is an '01 and the sending unit at least on the passenger side is on the back where it can be accessed from the rear fender well. Have'nt checked the drivers side to see if the pump is on the back on that side though.
Old Mar 20, 2005 | 08:14 PM
kosc01's Avatar
kosc01
2nd Gear
thanks for the help,I'll try it tomorrow
To fuel pump
