Cutting Exhast Pipe...
Old Mar 21, 2005 | 12:59 AM
Lithium's Avatar
Lithium
Default Cutting Exhast Pipe...
I had heard some guy talking the other day about cutting some the stock exhaust piping off behind the muffler and leaving the rest bolted up. I was wondering if anyone else has done this or something similiar. I plan to get a GHL catback system sometime in the future, but I really enjoy the sound of an open LS1. Anyone with experience in this area PLEASE chime in!
--Marc
Old Mar 21, 2005 | 01:44 AM
ditty22's Avatar
ditty22
I took my exhaust off and its dumping out at the end of the Hpipe and it sucks A$$!!! All the inside plastic vibrates like all hell so i would say dont do it. Only reason iv got my cat back off is cause one of the hangers broke off and i said to hell with it till spring
Old Mar 21, 2005 | 08:50 PM
Lithium's Avatar
Lithium
thanks bro! anyone else have any input??
--Marc
Old Mar 21, 2005 | 09:24 PM
happa's Avatar
happa
my 2 cents, if you like loud but not to loud take cats out, put in o2 sims and get you a good exhaust. Sounds good and loud. I have no cats and borla stingers and I get a lot of comments and people say that thing is loud as hell but sounds awesome at the same time, just my two cents, good luck
Old Mar 21, 2005 | 10:14 PM
FRISKY's Avatar
FRISKY
Cruise-In III Veteran
You can build straight pipe exhaust by cutting the mufflers off of a stock steel "over the axle" pipe and welding on a 1-foot piece of straight pipe. Even though it will be made of heavier metal, it will save about 10-pounds over the stock Ti mufflers.
It has a nice sound but is loud when above half throttle. It will also have some resonance in a couple areas of the rpm range.
I built a set of straight pipes (to use at the track) for my '02 Z06. It takes about 20-minutes to swap out the stock Ti exhaust for the steel straight pipes.
Old Mar 22, 2005 | 12:01 AM
2000GC5's Avatar
2000GC5
I did the same..cut off the muffs and made some striaght pipes with some nice tips. I think it sounds great, has a nice deep sound and when you step on it, it sounds better then any cat back I have heard. The key to having a good striaght pipe sound is to have tail pipes with tips, if you just cut off the mufflers it will sound like ****. You will also notice a little increase in power
Old Mar 22, 2005 | 02:23 AM
Lithium's Avatar
Lithium
Cool. Thank you all for your help. I think I know what I am going to do. When i get it done I will post pics! thanks again!
--marc
To Cutting Exhast Pipe...
