installed headers removed air pump tubes
Old Mar 22, 2005 | 06:23 PM
vettes4fun's Avatar
vettes4fun
Default installed headers removed air pump tubes
I removed my factory headers and installed a set of BBK headers on my 97. I also removed my air pump tubes and welded up the holes in the new headers. Now I am getting a check engine light code PO410. This a air pump code where the pcm tells the pump to run and it checks to see a change in the 02 sensors. My question is, if I install the 02 simulators in the rear by the converters, will it take care of the check engine light & code
Old Mar 22, 2005 | 06:48 PM
T_Vert's Avatar
T_Vert
no you need to edit out the code.
dave
Old Mar 22, 2005 | 06:59 PM
vettes4fun's Avatar
vettes4fun
How do you do this
Old Mar 22, 2005 | 07:12 PM
T_Vert's Avatar
T_Vert
you need a tuning software like ls1edit/hp tuners etc to do it. Where are you located ?
Dave
Old Mar 22, 2005 | 07:49 PM
vettes4fun's Avatar
vettes4fun
mayfield ,ky
Old Mar 22, 2005 | 07:52 PM
T_Vert's Avatar
T_Vert
what year car?
Dave
Old Mar 22, 2005 | 07:54 PM
pdd000's Avatar
pdd000
what did you do to plug the hole in the air box??
Old Mar 22, 2005 | 08:05 PM
T_Vert's Avatar
T_Vert
i used a push in gromett initially but it fell off. Its been an open hole for about 6 months now
Dave
Old Mar 22, 2005 | 08:11 PM
vettes4fun's Avatar
vettes4fun
Old Mar 22, 2005 | 08:13 PM
vettes4fun's Avatar
vettes4fun
I used a after market cold air system
Old Mar 22, 2005 | 08:38 PM
T_Vert's Avatar
T_Vert
i cant help you w/ a 97. someone who can tune the 97s can turn that code off in a matter of seconds.
dave
Old Mar 22, 2005 | 08:50 PM
pdd000's Avatar
pdd000
Dave
were'd you get a gromett that size? id like to get one so i dont have a big hole there in the air box
Old Mar 22, 2005 | 08:52 PM
T_Vert's Avatar
T_Vert
i dont remember i think i got the plastic ones at ace hardware
Old Mar 22, 2005 | 11:32 PM
FallenWhun's Avatar
FallenWhun
just curious, how much would it cost to have the code edited out?
To installed headers removed air pump tubes
