Drivers Side Turn Signal REALLY Fast
Old Mar 22, 2005 | 07:35 PM
chefkretz's Avatar
chefkretz
Default Drivers Side Turn Signal REALLY Fast
On my way home from work this evening, I signaled left and the flasher was clicking twice as fast. The rear lights were working but moving faster and the front was not blinking. When I put it in hazad mode it was flashing at normal speed. The passenger side is just fine?
I installed a new stereo well over a month ago and this is the first time it has happened? Where do I begin to look?
Thanks in advance!
Old Mar 22, 2005 | 07:42 PM
PrayN4C5's Avatar
PrayN4C5
i believe thats the flash to pass feature...
Old Mar 22, 2005 | 07:43 PM
Dave Witman's Avatar
Dave Witman
Check to make sure that none of your bulbs are burnt out on the side in question.
Old Mar 22, 2005 | 07:47 PM
4deatr's Avatar
4deatr
Yep check your bulbs one is out.
Old Mar 22, 2005 | 08:35 PM
IJustSmile's Avatar
IJustSmile
Definitely a bulb.
Old Mar 22, 2005 | 08:43 PM
birch64's Avatar
birch64
Originally Posted by IJustSmile
Definitely a bulb.
bulb.....
Old Mar 22, 2005 | 10:14 PM
FRISKY's Avatar
FRISKY
Cruise-In III Veteran
The left front bulb is out...
Old Mar 22, 2005 | 10:26 PM
ptdrummer54's Avatar
ptdrummer54
CI 5-6-7-8 Veteran
St. Jude Donor '04-'05-'06-'07
NCM Ambassador
OK, so now how do you get at it? Go in through the front brake duct - you can maneuver it aside and reach the back of the housing that way. The bulbs can melt holes in the top of the housing - try to check for that while you're in there.
Old Mar 22, 2005 | 10:34 PM
PaPaChoc's Avatar
PaPaChoc
Thanks in advance!
It's the bulb!
Old Mar 22, 2005 | 11:59 PM
ajderzie's Avatar
ajderzie
Yet another happy customer of the corvetteforum!
Old Mar 23, 2005 | 05:01 PM
chefkretz's Avatar
chefkretz
Man I tell you what, I never doubted any of you but it was the bulb! Problem fixed!
The best part was changing it in the garage with the temperature below 30!
Thank you everyone for the help
Old Mar 23, 2005 | 10:42 PM
VLVETTE's Avatar
VLVETTE
To Drivers Side Turn Signal REALLY Fast
