LS2 vs. LS6
Old Mar 23, 2005 | 12:55 AM
extremecorvette's Avatar
extremecorvette
Default LS2 vs. LS6
What is the diffrence besides the bore size, can I put the LS2 in my C5 with out any mods?
Old Mar 23, 2005 | 06:53 AM
ICULUKN-C5's Avatar
ICULUKN-C5
The ls2 has extrernal sensors, the ls6 has internal. There is some modifications that have to be done to fit a ls2 in a c5. One that I can think of is the throttlebody for the ls2 is a 90mm and is not a plug and play. You have to splice wires to get it to work right. There are other sensors that need to be relocated as well.
Old Mar 23, 2005 | 07:17 AM
AFVETTE's Avatar
AFVETTE
You'd be better off with an LS6. Form looking at all the dyno numbers finally being posted by new C6 owners it appears on a good strong LS2 you may see 352-355 RWHP. That's about average for an LS6 and it will drop right in.
Tom
Old Mar 23, 2005 | 11:30 AM
TopCat's Avatar
TopCat
Tom
That's interesting info. I'll have to go check the charts.
Edit:
with Tom.
Old Mar 23, 2005 | 11:49 AM
Tony Mamo @ AFR's Avatar
0Tony Mamo @ AFR
Former Vendor
Unless your building an LS2 based stroker (utilizing the larger bore block), it's probably not worth the hassle. At this point no one has figured out a way to get the knock sensors to work although I have a feeling that will ultimately be worked out. Besides that there is some wiring harnesses to extend etc,....a very workable situation, but considering the swap for only a modest increase in displacement doesn't seem worth the BS yet.....Down the road I bet all the little "nuances" are handled and it will become more of a plug and play type of situation.
Tony M.
To LS2 vs. LS6
