I have a '99 coupe in need of new tires. I would like to replace them with non runflats. It seems everyone has dealt with this question except me! What will "Fix a Flat" do to the wheel sensors in my C5?Is "Fix a Flat" an option for a repair on the road? I travel a lot! I would hate to get stuck in the middle of the night with a flat and no options for a repair!
If you remove the sensors or band the sensors to the center of the wheel then its not an issue. If you keep the sensor at the valve stem, you will ruin it with fix a flat.
Here is what I did. I went to napa a got their tire inflater kit with small air pump and fix a flat. I also got a vulcanizing plug kit. I figured if I get a flat I will try the plug first if all else fails I will use the fix a flat. I also have a very small sissors jack and puck along if needed. It all fits in one of the small storage wells. Total cost $75 Dave.
The fix a flat will clog the tire pressure sensors. However, you should weigh the cost of a new sensor against the cost of experiencing a flat and having to have the Vette flatbedded to a place to have the tire removed and repaired / replaced. Your time and additional concerns of having you Vette taken for a ride on a flatbed should be considerd also.
So for peace of mind, I would get a can of fix-a-flat and not worry. Yes the valve stems are about $125.00 each, but how often do you think you will actually experience a flat and using the fix-a-flat, probably not very often.
Many on the forums carry a plug kit and small compressor for emergency roadside tire repairs. You can make your own by going to Wal-Mart and purchasing a small plastic container, needlenose pliers, plug kit, small 12VDC compressor with a very long cord, and a few towels wipes.
I don't have the pressure sensors, so I'm not worried about that, but if I ever have to use the fix-a-flat, what will it do to the inside of the tires? I'm guessing that I would still have to get the tire patched, but does the fix-a-flat stuff come off with no problem?
fix a flat is not a permenant solution.. It is only there to get you to a repair shop. In high school I worked for a tire place, and I can tell you I hated when people used fix a flat.. Its a messy.. messy foam that gets everywhere when you break the bead. Anyway.. the foam comes right out and you can patch the tire.
I think it depends on which formula you get. There is a waterbased type (GM's Z06 goop is this type) and the other type is a petroleum based formula, not sure exactly what it is.
I've been doing this for years...except I still refuse to use fix-a-flat. Over a dozen flats fixed in the past 4 years...100% success rate.
My '03 Owner's Manual strongly cautions against the use of "Fix-a-Flat" and the like if you have tire pressure sensors installed. You might want to check what yours says. Good luck with the tires.
