Window adjustments?
Old Mar 23, 2005 | 03:28 PM
silkywilson's Avatar
silkywilson
Default Window adjustments?
new guy here recently purchase a EB 02 Z06 anyhow to the problem.. I noticed at 135MPH my passenger window made ALOT of wind noise, but none at 125MPH, then 3 days later In a car was noticed 1 or 2 drops of water also from the same window.. I read some where there was a TSB for it but it wasnt anything but somthing saying TSB for wind noise window adjustment. Can some one please advise me on what the correct fix is for this?
Old Mar 23, 2005 | 03:52 PM
djengr's Avatar
djengr
Seems like I saw a thread on this subject recently, but I don't remember which forum I saw it on. Basicaly there is a removable plate or piece on the bottom of the door. This will give you access to jacking screw/bolt where you can adjust lateraly the position of the window in the track. This would put more force on the weather strip. If there are no other responses tonight I will look up in my service manual at home.
Old Mar 23, 2005 | 08:56 PM
c5wolf's Avatar
c5wolf
anyone?
Old Mar 24, 2005 | 02:19 AM
silkywilson
Ill see if I can find this plate tomorrow when I got light and room to work and post what if anything I find out...
Old Mar 24, 2005 | 06:09 AM
Johnny5's Avatar
Johnny5
You are lucky if you only get the noise at 135, mine starts at 70. I'm looking for the same info as you, but also looking for how to adjust weather stripping on the targa top (i remember reading about a pretty simple procedure to move a slide under the weatherstipping that will help fix this, but I can't find it now). anyone know of a link to this procedure? Thanks
To Window adjustments?
