T/C plus Transgo shift kit-worth it?
Old Mar 23, 2005 | 11:44 PM
Target Chaser's Avatar
Target Chaser
From: Machine Silver Z06 The Golden State......... Bay Area
St. Jude Donor '05
Default T/C plus Transgo shift kit-worth it?
I am considering upgrading my T/C and possible gears (I have the 3.15's now). When I do this should I get a shift kit as well?
Also any suggestions on T/C and gears will be welcome. I want a definate improvement over stock but not a beast that's unfit for daily driving. I know Yank is all the rage here but I have heard good things about the P.I. Vigilante from my local Tech.
Down the road I will also look at Heads and a cam so I want to be prepared for the future. If I do the gears I'll get the hardened output shaft and HD gears.
Thanks.
Old Mar 24, 2005 | 03:11 PM
Target Chaser
St. Jude Donor '05
bump, anyone?
OK, so the title could have been better.
I am thinking of the 3.42's and PI Vigilante TC (2800).
Should I get a shift kit too, Predator tuner, or both?
Any help, suggestions is welcome.
Old Mar 24, 2005 | 03:47 PM
JSTAN's Avatar
JSTAN
Definately worth installing. The shifts are much firmer. I upgraded my A4 last year, I went from 3.15's to 3.42's, SY3500 TC and Transgo. I used 2 shims for the shift kit, when you manually shift from 1 to 2 you chirp the tires.
Old Mar 24, 2005 | 04:07 PM
Target Chaser
St. Jude Donor '05
Awesome, thanks that's what I looking for!
Old Mar 24, 2005 | 04:19 PM
patrickboyle's Avatar
patrickboyle
Hey Target, looks like you are west coast. I have a qoute from DTE for 3.90's Yank SY3300 & PCM programming. I'm leaning towards this as my setup with the only exception being possibly 3.73 gears instead. Right now 3.73 are not available. I've heard good things about the above combo but can't say for sure until the work is done.
Old Mar 24, 2005 | 04:24 PM
4deatr's Avatar
4deatr
You will need one more thing TIRES.
I love my shift kit
Old Mar 24, 2005 | 06:11 PM
vstella's Avatar
vstella
ABSOLUTELY a MUST DO!!!
Old Mar 25, 2005 | 10:04 AM
KRK's Avatar
KRK
Definitely.
To T/C plus Transgo shift kit-worth it?
