Help!!!!
Old Mar 24, 2005 | 06:41 PM
DonsLS1's Avatar
DonsLS1
Default Help!!!!
Does anyone know which fuse would control the lights for the driver and passenger side window controls? All the switches work, I just have know lights in those panels. I checked the manual, but had no success.
Old Mar 24, 2005 | 06:52 PM
servohead's Avatar
servohead
mmh, sounds like that's internal in the window switch modules. I've never taken one apart, if they come apart - there may be a bulb that you can replace in there.
Old Mar 24, 2005 | 10:11 PM
purrvert's Avatar
purrvert
The door lights are tied to your instrument cluster dimmer switch then branch off to each individual door control module through a data link connector. The lights are controlled by pulse width signal to ground. Everything seems to originate from the BCM.
Let us know what you find.
To Help!!!!
