Recall Flywheel - is this necessary
Old Mar 25, 2005 | 07:48 AM
aschon's Avatar
aschon
Default Recall Flywheel - is this necessary
Dear all
I have just got the PCM of my C5, 1998, reflashed. When I got the car back from the dealer he said that there would still be a recall open concerning the fly wheel. Does anybody of you have any experience with this recall, is it necessary, how difficult is it, is there anything I should let the dealer know (I am in Switzerland and I am almost sure that this is the first time he does something like that)?
I am grateful to any comments from your side on this issue.
Best regards,
Andreas
Old Mar 25, 2005 | 07:54 AM
6SPD98's Avatar
6SPD98
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18- '19
Default Recall
________________________________________ ____________________
[aschon]Dear all
Haven't heard of a "flywheel" recall. The only other one I received was for the seat belt, I believe it was for the "retractor" part of the seat belt
Best regards,
Andreas[/QUOTE]
Old Mar 25, 2005 | 08:31 AM
Patches's Avatar
Patches
I couldn't find a specific recall or TSB about this but there has been discussion on this forum about flywheel bolts that were improperly torqued at the factory which threw off the clutch alignment and caused a vibration in the driveline. Replacing the flywheel (torqued correctly), friction disc and pressure plate fixes the problem.
Old Mar 25, 2005 | 10:09 AM
ArmyVette's Avatar
ArmyVette
I've found that Corvette Action Center's Knowledgebase is pretty good for tracking TSBs and Recalls. It doesn't show anything under Clutches and Transmissions pertaining to flywheels.
Here's the link:
Corvette Action Center's C5 Clutches and Transmissions Knowledgebase
Old Mar 25, 2005 | 01:39 PM
aschon's Avatar
aschon
Dear all
Thanks a lot for your answers. I will try and find out more about it.
Besides the PCM recall I also had the seat belt recall done -it is just the "retractor" as you mentioned.
Best regards,
Andreas
To Recall Flywheel - is this necessary
