patriot 5.3 heads
Old Mar 26, 2005 | 03:59 PM
flynbya2's Avatar
flynbya2
St. Jude Donor '05-'06
Default patriot 5.3 heads
Again, I'm in emissions tight Ca.
These heads increase cr correct?
Well, our premium is only 91 octane here, so the question is.....
Will these perform properly if I install them? Will there be knock issues?
Or are they perfectly fine for my application?
I have an a-4 and may go with a moderate cam(about as strong as I can go,apparantly, is somewhere in the 224 range,I would consider pushing it to a 224/228 if you guys think I could pull it off without issues)and I don't want a bunch of problems......emissions or whatever!
I'm just trying to educate myself instead of spending a lot of time and $$$$ only to have to undo whatever I have done
Any comments appreciated..you guys are the greatest.. I LOVE THIS PLACE!!!!
Old Mar 26, 2005 | 05:03 PM
90 droptop's Avatar
90 droptop
11 to 1 is fine with a quality tune.
Old Mar 26, 2005 | 05:27 PM
flynbya2's Avatar
flynbya2
Somehow, I knew I could count on you 90 droptop! Anyone else with thoughts?
Old Mar 26, 2005 | 06:15 PM
Gray Ghost GS's Avatar
Gray Ghost GS
"AlohaC5" Senior Member
I pass the tough dyno-based sniffer emissions test in Fairfax County, Virginia with my Patriot Performance 5.3L Stage 3 heads that are 61cc with the larger intake and exhaust valves and Patriot Gold dual valve springs. I'm about to upgrade to the AFR 205 Mongoose heads in June and will be selling my PP heads for $800.
Old May 20, 2005 | 08:57 PM
Jerryk's Avatar
Jerryk
Default bolt on
can i just bolt the heads on without running into any problems? Looking at the AFR Mongoose 205 as well
Old May 20, 2005 | 09:00 PM
Gray Ghost GS
The 5.3 LS1 heads are a direct bolt-on just like any other LS1 style head - no problem at all. Mike
Old May 21, 2005 | 04:19 PM
MikeV's Avatar
MikeV
Aloha
If you don't already have a buyer for your heads, put me first in line.
Mike V
Old May 21, 2005 | 05:06 PM
Gray Ghost GS
Mike: I have one buyer identified for my PP 5.3L Stage 3 heads. You are #2. I expect to close the deal with this guy on 4 June (Saturday); however, if the deal isn't closed by the 7th - then they're yours. I will contact you either way to keep you in the loop. Thanks, Mike
Old May 21, 2005 | 05:31 PM
greg_nate's Avatar
greg_nate
Go with the PP heads...I got a pair with the new Gold springs and their lightweight valves for $750...just my opinion, but I'd save $1500 and make AhohaC5 an offer.
This is fodder for debate, but here's how I look at it: I bought PP heads for $750 and the Supermaxx header system for $1100...$1850 total and got them installed at the same time for a savings.
If I had gone with the AFR heads ($2400) and LG header system ($2000), I've have spent $4400...
So I sacrifice a few horsepower and save $2,550. For a guy like me who doesn't have unlimited funds, I can get similar performance for $2,550 less and be driving the mods RIGHT NOW !! Its a no brainer.
People debate the heck out of this on the forum, but for me its a clear, wise choice. For the price of the AFRs, I got a great, proven set of heads and headers installed...If not, I'd still be driving a stocker, trying to save up for the LGs and letting the heads sit and get dusty waiting for the install....maybe for a year, who knows. And while the parts sit, I don't know if they're good or not or defective or what. The last thing I want to be doing is to try to track down a warranty a year after the purchase. Forget it. Let those with lots 'o $$ debate and flame. I'd rather be driving.
greg
Old May 21, 2005 | 07:05 PM
99torchredlb's Avatar
99torchredlb
Old May 22, 2005 | 02:05 PM
jjjflex's Avatar
jjjflex
greg
Nice point!!
Old May 22, 2005 | 03:28 PM
Tino's Avatar
Tino
With the 224 to 228 overlap @.50 you should be okay. The cam will bleed down cylinder pressure and reduce the chance of detonation.
Tino
To patriot 5.3 heads
