A4 upgrade advice needed
Old Mar 27, 2005 | 02:40 PM
Wt99C5's Avatar
Wt99C5
Default A4 upgrade advice needed
I’m in the planning stages of a drive line upgrade and have a few questions.
This is an A4 to A4 upgrade.
1. I’ve found a few local trany shops claiming they can use bulletproof internal parts. What I don’t know is what I should be looking for. Is there a list of must have parts that should be used? Also, another option would be FLP and a forum member known for building great tranys. Options please.
2. Has anyone done the swap in their garage without the use of a lift ?
3. TC and gears will go in at the same time. Car is mostly street driven. Current plan is a SS3200 and 3.42 gears. Any feedback here would be great.
4. Anyone have a DIY on the swap ?
Old Mar 27, 2005 | 03:07 PM
Wt99C5's Avatar
Wt99C5
One more question.
I purchased a head and cam package which included tuning. Patches and I did the install. I recently started tuning with EFI V7 and went back to the STOCK tune. Last week I was comparing files and noticed that the tuner had made a few changes in the trans area. BTW, the reason I’m upgrading is slippage between first and second. I have NO trany related codes. Is it possible that the tune could cause the slippage between gears ?
Old Mar 27, 2005 | 07:17 PM
sams96's Avatar
sams96
On the trans I would go with Rodney(crashed94). On the converter and rear I would go bigger. I did my converter and rear swap using jack stands and it took me 5 hours and it was my first time.
Old Mar 27, 2005 | 07:45 PM
Wt99C5's Avatar
Wt99C5
" 5 HOURS "
What special tools did you need?
What's your thoughts on 1st to 2nd slippage? I don't have any codes. Could the stock PCM program cause this ?
I'll contact crashed94 for details.
Old Mar 27, 2005 | 07:53 PM
2001 Red Coupe Bandit's Avatar
Go minimum SS3600, Ideally SS3800 with 3.73 geards, or 3.42's will work if ya want.
I had an SS3600, then went to an SS4000. I like it! I think the SS3800 might have been a happy medium in everyday driving, but the SS4000 isn't that loose for a 4000 and I have 3.42 gears
Old Mar 27, 2005 | 08:05 PM
Wt99C5's Avatar
Wt99C5
Bandit, You still running the stock trany ?
Old Mar 27, 2005 | 08:11 PM
sams96's Avatar
sams96
No special tools needed I asked a local GM dealer the tech time needed for a converter swap and they said 6 hours. If I were to change my converter again I think I could do it in 3 1/2 to 4 hours. It's not hard at all. On the 1-2 shift it sounds like the cluth pack for the 1-2 is going bad. Someone said that GM used a paper cluth with a friction material coating to cut cost don't know if that's true. And yes I'm still running the stock trans but I do have a trans-go shift kit. And I have a 233/239 cam from TSP in my car thats been in there for over a month now. Can't wait to get to the track.
Old Mar 27, 2005 | 08:24 PM
Wt99C5's Avatar
Wt99C5
I'd be happy to get it done in 1 maybe 2 weekends.
Paper clutch,, great.
I'm running a little 224 cam, I'd say I'm in the 350 to 370rwhp range.
Really makes me wonder if the trany's not going bad and something else is wrong.
To A4 upgrade advice needed
