headlight switch malfunction...loose wire?
Old Mar 27, 2005 | 04:34 PM
goldlifter's Avatar
goldlifter
Default headlight switch malfunction...loose wire?
as the title says, my headlights are malfunctioning and will stay up all the time. if i turn the **** PAST the "off" setting, then they will momentarily drop down, but go back up shortly thereafter. is there any way to fix to this in a small amount of time?
Old Mar 27, 2005 | 04:56 PM
talon90's Avatar
talon90
Cruise-In 11 Veteran
NCM Ambassador
St. Jude Donor '05-'06-'07-'10
It sounds like you might have a gear going. Is it both, or just one that does it?
Paul
Old Mar 27, 2005 | 04:58 PM
talon90's Avatar
talon90
NCM Ambassador
It sounds like you might have a gear going. Is it both, or just one that does it? If it's both you probably have a problem with the switch as you mentioned....have you tried just cycling the switch and maybe hit it with a spritz of contact cleaner?
Paul
Old Mar 27, 2005 | 04:59 PM
goldlifter's Avatar
goldlifter
yep, its both
Old Mar 27, 2005 | 05:56 PM
goldlifter's Avatar
goldlifter
letting some isopropyl alchohol (91%) run through it fixed it, thanks!
Old Mar 27, 2005 | 08:35 PM
Ag_bullet's Avatar
Ag_bullet
Can you just clarify this for me now... I think I'm having the same issue.
The switch on the turn signal stalk that should turn lights on and off wasn't working and your solution was to soak some iso-propanol on the end of the stalk? Or spritz some contact cleaner into the gap between the turning end and the rest of the stalk...?
Old Mar 28, 2005 | 11:06 AM
goldlifter's Avatar
goldlifter
i put a rag underneath the unit and let the alchohol run down the gap in the unit
To headlight switch malfunction...loose wire?
