What Offset range can I use for C5 Coupe, LUG Patern? 5 X 114, and what is the max size I can use? I would like to run 345's in the rear. I know I'm going to have to tub the car out.
A guy in my home town is selling his 03 viper and he is selling his HRE rims and the Front are 19x10 front tires 275/30ZR19 Rear 19x13 tires 355/25ZR19 tires. Will they fit, I need to find the offset and lug pattern for corvettes and will have to tub the rear.
I was told that a Offset +64mm 18x12 rim doesn't need tubing?
If it's 54mm, then no, it may not. But it will stick out of the fender.
That is the only purpose of tubbing. To tuck a wider wheel/tire without it sticking out of the fender. Your initial post said you would tub, so hence my answer (for a correct fitment on a tubbed car)..
If you don't mind it sticking out of the fender, then you can run any width you want and not have to tub. Offset it accordingly
