Pics: Aussie Clutch Arrived Today!
Old Mar 28, 2005 | 09:53 PM
Z06-JIM's Avatar
Z06-JIM
Cruise-In VII Veteran
Default Pics: Aussie Clutch Arrived Today!
(I mistakenly posted this in the General Section and meant to post it here.)
Got my Textralia Aussie Clutch in today I ordered from Chris @ ECS! Just like another forum member posted a few days ago, Jeff at Textralia called me to make sure clutch made it here O.K. and to see if I had any questions! It just doesn't get any better than that for customer service! Probably will be a couple weeks before I have it installed and will post my opinions then.
Old Mar 28, 2005 | 10:09 PM
Cajundude's Avatar
Cajundude
Active Streak: 90 Days
Cruise-In 7-8-9-10 Veteran
St. Jude Donor '06-'07-'08-'09-'10-'11-'12
That clutch looks sweeeeeet! Maybe I'll do a burnout next time at the track with the clutch half way in.
Old Mar 28, 2005 | 10:18 PM
silverz06vette's Avatar
silverz06vette
How much approx are they?
Old Mar 28, 2005 | 10:24 PM
Cajundude's Avatar
Cajundude
I've tried asking this question, twice (two different posts), and also sent a PM to ECS but never got a reply to any of them. Must be a top secret or something .
Old Mar 28, 2005 | 11:03 PM
Chris@East Coast Supercharging's Avatar
Premium Supporting Vendor
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In V Veteran
Thanks for your business Jim.. Keep me posted when you get it installed..
Old Mar 28, 2005 | 11:05 PM
kumar75150's Avatar
kumar75150
They are around $950 for the whole kit including a new slave etc.
Cruise-In V Veteran
Sorry about that. Who did you send the PM to? I do all the sales and pricing. If you sent it to Doug it sometimes takes awhile because we have been really busy in the shop. I just sent you a PM now..
Old Mar 28, 2005 | 11:10 PM
Z06-JIM's Avatar
Z06-JIM
It cost me $974 delivered 2nd day air and clutch is balanced ready to install when you receive it.
Old Mar 28, 2005 | 11:29 PM
JetVette01's Avatar
JetVette01
what is all included? Flywheel?
Old Mar 29, 2005 | 09:14 AM
J-Rod's Avatar
J-Rod
Glad to hear they got you fixed up Jim. How is the beast doing these days?
Old Mar 29, 2005 | 10:32 AM
Jeff Jeff's Avatar
Jeff Jeff
LUK told me my clutch was balanced from the factory as well. After installing it I had to pull it and found it was over 16 grams out. I would have the balance double checked.
If you have a stock engine, chances are it was final balanced with weights on the flywheel. You should have the old clutch assembly balanced to the new one to avoid balance issues.
Old Mar 29, 2005 | 10:36 AM
Cajundude's Avatar
Cajundude
No problem. Not sure who I sent it to, I think it was to you or Doug in the other post about this clutch. In any event, I got your PM so no big deal. I'll let ya'll know when I'm ready. Thanks!
Old Mar 29, 2005 | 12:01 PM
5 Liter Eater's Avatar
5 Liter Eater
St. Jude Donor '11
To my knowledge that $950 gets you the disk, pressure plate, flywheel, slave (slave and throw out, not just the throw out like other clutches give you), pilot and master (not 100% sure about the pilot and/or master).
I am by no means bashing or doubting Textralia but that pic looks very similar to a Clutch Masters stage IV six puck seen here:
http://www.clutchmasters.com/shop/?p...768&AppID=5091
The difference being (at first glance) that Textralia includes everything for the same price as the Clutch Masters disk and pressure plate. The Clutch Masters may perform similar to the Textralia but may have been overlooked due to it's high price.
Let me re-iterate that this is not to question either vendor or raise any questions as to either's authenticity. I am very glad to see a new clutch design for the LS1 that seems to show so much promise! I just noticed that they are of similar design, thats all.
Old Mar 29, 2005 | 12:52 PM
BLU-BY-U's Avatar
BLU-BY-U
the pressure plate design looks somewhat different to me, not to mention the aussie bolt pattern on the disk material is on a vertical line, while the CM is horizontal. I have no idea if this makes one more favorable than the other, just an observation.
Old Mar 29, 2005 | 01:19 PM
5 Liter Eater
St. Jude Donor '11
You're right. The more I look at them the more differences I see. Think I just jumped to this incorrect conclusion.
Old Mar 29, 2005 | 06:21 PM
Ruby6spd's Avatar
Ruby6spd
Looking forward to hearing your results
I need a new clutch and my head is spinning with all the problems we have seen with the aftermarket parts
Old Mar 29, 2005 | 06:47 PM
C54DAZ's Avatar
C54DAZ
That P/plate is identical to my spec II? But its blue not yellow. Dont worrie though, I love my spec II and it works great, In case they are of a similar design.
To Pics: Aussie Clutch Arrived Today!
Old Apr 5, 2005 | 11:03 PM
roSSco's Avatar
roSSco
That sounds great! What does it cost to have a clutch replaced in a C5?
Old Apr 5, 2005 | 11:10 PM
silverz06vette
$500-$900 depending on where you get it done.
Old Apr 5, 2005 | 11:44 PM
NEPTUNEBILL's Avatar
NEPTUNEBILL
The clutch has the dowl pins that make the install perfect and the balance is perfect when you put it in--I was talking to peter in aussie a couple of days ago and they pulled one out of a holden (3900lbs) that has 750rwtq and over 200 1/4 mile runs as well as 22,000 miles as a daily driver and there was just under 25% of the disk material missing so I would have to say the clutch should last me quite awhile--I loved this clutch right up until the time the car went head first into the gaurd rail friday night in the rain--still love the clutch but the car is fkd.
